Tractor died - now trying to troubleshoot - issue seems to be electrical
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #21
Given the test you showed earlier, it's extremely unlikely that the battery itself is the issue. Beg, borrow or buy a volt meter, and a pack of 'clip leads'. Scrounge up some small gauge wire, about 10-15' long. Then we can talk about troubleshooting.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #22
Anyone who owns a tractor should
have a parts list for their tractor so
is someone tells them about a part
they can find it. Also a parts list has
part numbers so if need be you can
order or find the part you need.
willy
Hey All. Just following up as I don't want to be 'that guy' that posts a problem and leaves the post un-answered. Long story short - bad connections. Thinking we had a starter issue, I disconnected the battery and starter, removing it from the tractor. After a test proving that the starter was good, I cleaned ALL the contacts, put it back together and it started right up when I turned the key. Moral of my story - CHECK YOUR CONTACTS! Thanks all!!!!
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #24
Glad you got it solved and it was an easy fix. Thanks for the update.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #25
Glad you got it going and thanks for the feed back.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #26
As others have said, thanks for closing the loop.
best,
ed
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
