Tractor died - now trying to troubleshoot - issue seems to be electrical
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #21
Given the test you showed earlier, it's extremely unlikely that the battery itself is the issue. Beg, borrow or buy a volt meter, and a pack of 'clip leads'. Scrounge up some small gauge wire, about 10-15' long. Then we can talk about troubleshooting.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #22
Anyone who owns a tractor should
have a parts list for their tractor so
is someone tells them about a part
they can find it. Also a parts list has
part numbers so if need be you can
order or find the part you need.
willy
Hey All. Just following up as I don't want to be 'that guy' that posts a problem and leaves the post un-answered. Long story short - bad connections. Thinking we had a starter issue, I disconnected the battery and starter, removing it from the tractor. After a test proving that the starter was good, I cleaned ALL the contacts, put it back together and it started right up when I turned the key. Moral of my story - CHECK YOUR CONTACTS! Thanks all!!!!
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #24
Glad you got it solved and it was an easy fix. Thanks for the update.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #25
Glad you got it going and thanks for the feed back.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #26
As others have said, thanks for closing the loop.
best,
ed
1762 (A58375)
1762 (A58375)
17102 (A56859)
17102 (A56859)
Box of 7 Game Cameras (A57454)
Box of 7 Game...
John Deere 1600 Turbo Series II (A57453)
John Deere 1600...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
