Tractor died - now trying to troubleshoot - issue seems to be electrical
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #21
Given the test you showed earlier, it's extremely unlikely that the battery itself is the issue. Beg, borrow or buy a volt meter, and a pack of 'clip leads'. Scrounge up some small gauge wire, about 10-15' long. Then we can talk about troubleshooting.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #22
Anyone who owns a tractor should
have a parts list for their tractor so
is someone tells them about a part
they can find it. Also a parts list has
part numbers so if need be you can
order or find the part you need.
willy
Hey All. Just following up as I don't want to be 'that guy' that posts a problem and leaves the post un-answered. Long story short - bad connections. Thinking we had a starter issue, I disconnected the battery and starter, removing it from the tractor. After a test proving that the starter was good, I cleaned ALL the contacts, put it back together and it started right up when I turned the key. Moral of my story - CHECK YOUR CONTACTS! Thanks all!!!!
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #24
Glad you got it solved and it was an easy fix. Thanks for the update.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #25
Glad you got it going and thanks for the feed back.
   / Tractor died - now trying to troubleshoot - issue seems to be electrical #26
As others have said, thanks for closing the loop.
best,
ed
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
