Tractor Cover
   / Tractor Cover #1
Dirt Farmer
Northern, VT
Kubota 3700SU
I am looking to protect my tractor (Kubota 3700SU) from the elements especially during winter until I can build a storage area. I found a tractor cover online from covermytractor.com. Has anyone had experience with this type of cover or could anyone recommend a similar type cover? Any advice on winter stroage would be much appreciated. :)
   / Tractor Cover #2
Know couple gentlemen use heavy mill blue tarp extra size..easy to handle also if repairs etc. needed plenty of coverage..until shed etc. built.
   / Tractor Cover #3
I wouldn't recommend the temporary shelters from Shelter Logic, unless you're sheltered from the wind. Mine lasted a month maybe, then turned into a twisted pile of fabric and steel pipe. Luckily the tractor wasn't in it at the time.
Sean
   / Tractor Cover #4
I know Chilly doesn't like them but this is add-on was on of my late summer projects before hunting season starts.....
It is protected from the wind and I have two neighbors with the same (One three years old and one 4 yrs old)......
Shelter-Logic does make heavy duty models and heavier fabric if you pay for it.....
This is 12' w x 20' deep x 8' high.....picked up in Nashua, NH $549
.http://sheltersofnewengland.com/downloads/prepack/12 WIDE ROUND.pdf
   / Tractor Cover #5
Unless you strap a tarp down tightly with bungee cords, the wind will make it flap and it will rub the paint off on some corners and edges of the sheetmetal.
   / Tractor Cover #6
Here's a pics of the internals, no much more than a HD Tent......:laughing:.....all you need is the Circus Elephants.......well maybe small ones......
   / Tractor Cover #7
Found that my portable garage has worked well so far. It does get some wind but is bolted down well. 10 X 20 ft and the tractor just fits in without having to lower the ROPS.:)
  • 670DecemberPics 178.JPE
   / Tractor Cover #8
I have a Shelter Logic 12 X 20 that's been standing 3 years and withstood winds up to 80 mph.
It has a few small leaks where the cover has rubbed on the poles, but other than that, NO problems at all.
Mine is anchor bolted to a concrete pad
   / Tractor Cover #9
Like Chilly, we tried a portable shelter years ago and it lasted a month. It was exposed to direct wind.
   / Tractor Cover #10
In my experience, it was an all-or-nothing thing. From what I could tell of what was left, one bolt broke, then the frame could move a bit. The rest soon followed. I had 24 inch ground anchors in frozen ground, they never moved one inch.
With heavy enough pipe, and welded construction, they'd be fine I think. Like I said, if you're in a sheltered area and don't get a ton of snow, they should be ok.
Sean
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
More info coming soon! (A50323)
More info coming...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
