Tractor caddy recommendation
/ Tractor caddy recommendation #1
Aggie66
Rockdale TX
MX 5400
I have a Kabota MX 5400 and have a need for a caddy that I’m believing will fit between the two roll Bar post. Anyone have a recommendation on a caddy that has worked well for them. I plan on carrying just typical things a chainsaw a Gerry jug wrenches chains stuff like that. Any recommendations are appreciated.
/ Tractor caddy recommendation #2
You can make your own from a metal toolbox and parts from Menards.
Large one,
smaller one,
If it fits on my Yanmar, it should fit on your Japan made Kubota too!
/ Tractor caddy recommendation #4
You can make one for the 3-point lift too out of an IBC tote cage on the cheap.
Either free or under $30 off Craigs List in my area for a 250-gallon tote.
Then cut it to the height you want or cut out one side, or whatever . . .
Even a plastic 55-gallon barrel for $15 off Craigs List can be a nice carry all.
Use round PVC tubes mounted inside to hold things in place.
/ Tractor caddy recommendation #6
If you want a fancy 3-point cart on wheels with a carry-all,
This can be bought for several hundred dollars or build it for about $400 with all the parts from Harbor Freight.
/ Tractor caddy recommendation #7
I looked for something like has been shown here. Then I realized that a whole lot of what I do requires the hauling of large items - large rocks, large chunks of pine tree trunk. As well as small tools also. I decided to build a farm wagon. Bed is 8' x 12' and will carry 20K pounds. It's got a Horst 20K frame - 1 1/4 T&G plywood deck. AND - I'm finally pretty good at backing it up.
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
