Tractor caddy recommendation
/ Tractor caddy recommendation #1
Aggie66
Rockdale TX
MX 5400
I have a Kabota MX 5400 and have a need for a caddy that I’m believing will fit between the two roll Bar post. Anyone have a recommendation on a caddy that has worked well for them. I plan on carrying just typical things a chainsaw a Gerry jug wrenches chains stuff like that. Any recommendations are appreciated.
/ Tractor caddy recommendation #2
You can make your own from a metal toolbox and parts from Menards.
Large one,
smaller one,
If it fits on my Yanmar, it should fit on your Japan made Kubota too!
/ Tractor caddy recommendation #4
You can make one for the 3-point lift too out of an IBC tote cage on the cheap.
Either free or under $30 off Craigs List in my area for a 250-gallon tote.
Then cut it to the height you want or cut out one side, or whatever . . .
Even a plastic 55-gallon barrel for $15 off Craigs List can be a nice carry all.
Use round PVC tubes mounted inside to hold things in place.
/ Tractor caddy recommendation #6
If you want a fancy 3-point cart on wheels with a carry-all,
This can be bought for several hundred dollars or build it for about $400 with all the parts from Harbor Freight.
/ Tractor caddy recommendation #7
I looked for something like has been shown here. Then I realized that a whole lot of what I do requires the hauling of large items - large rocks, large chunks of pine tree trunk. As well as small tools also. I decided to build a farm wagon. Bed is 8' x 12' and will carry 20K pounds. It's got a Horst 20K frame - 1 1/4 T&G plywood deck. AND - I'm finally pretty good at backing it up.
2000 Volvo Semi (A66285)
2000 Volvo Semi...
(15) Kinze 48 Cell Bean Plates (A65640)
(15) Kinze 48 Cell...
2017 EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
2017 EZ-GO SHUTTLE...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
White 5100 12R 30" Planter (A66285)
White 5100 12R 30"...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
