Tractor Buying Advice
/ Tractor Buying Advice #21
Have you thought about ground clearance when you're mowing the "swampy areas"?
I agree that it can take a long time to clear snow with an FEL. A simple rear blade is probably quicker for less than 12" of snow.
I thought about ground clearance and considered some of the bigger machines such as the JD4000 TEN, B7500/B2410, TC30 and the prices on those machines equally configured are much higher. I also believe that I should be able to fill up the portions of the trail that are swampy, for use in all weather conditions, hence of the attraction for the back bucket.
/ Tractor Buying Advice #23
Seth,
Congrats on trying the BX22. You're going to find that in a new tractor nothing else is in that category at that price point, even if it is a "YUPPIE" tractor <laughing>.
I paid $ 16,500.00 for mine last month. It included the 60" MMM (make sure you adjust it yourself via the manual directions starting with Step # 1 or it will scalp the heck out of your yard) and a toothbar for the front end loader. I highly recommend the toothbar for any kind of scraping or digging with the front end loader (usually a $ 300 option). You should be able to get the same price from your dealer as well. I have found the BX22 to be up to any task I ask for it, and it's a great mower as well. I consider it one of the better buys I've made and have zero regrets or feel I need something larger or more powerful.
Now, if I can just get all those cool attachments !
-Duane C.
/ Tractor Buying Advice #24
For that size property, I suggest looking at utility tractors (Kubota M series, New Holland TN series, Deere 54XX, etc). They are priced close to the CUTs and you get a lot more capability.
/ Tractor Buying Advice #25
I too have been looking at buying a tractor. I have narrowed it down to the Kubota line as well. I think you get more perfornance vs price with the 'K'. I live in northern Virginia, and here the JDs' are overpriced when compared with the same options you get get with a NH or a K. The NH has a better PTO vs Engine HP performance than the other two, but the K, well it just gives you more for less.
I have been looking at the L3000. I have 4 acres, about 3 of which we mow, try to keep it 'park like'. I want the FEL, and am looking at the rear mount mower, with Turf Tires (the dealer told me he has not sold or even seen an L3000 with turf tires yet, but is not a problem to order one). I want the FEL for some clearing work, knocking over stumps, and moving some rip rap around with. I think it will be adequate for that, but I am not sure if it is overkill for the mowing of only 3+ acres.
Any opinions on this (I am sure there are...lol). Maybe a B series would be better for me, as I suspect over 90% of this tractors use will be mowing, especially after I finish clearing the land we want to clear.
I only have about a 50' driveway, so snow clearing will not be an issue.
Thanks for your help
Ira
/ Tractor Buying Advice #26
Ira,
The L3000 with a RMM and tooth bar on the FEL will likely suffice your needs, with the Ag tires probably OK unless you have a lot of soft soils/wetland grass areas. Also if you have mostly "one gear" operation (not a lot of turning/back forth movement) the L3000 with the HP and size will work very well.
Yes, we want to help you spend your money (wisely) so you should check out the BX22 series - the BH is worth the investment, and the MMM setup with removable FEL might be worth considering pending the tree stumps and other things (plant this right here requests from the CFO) you will likely encounter.
Good luck and Happy hunting,
Carl
/ Tractor Buying Advice #27
Darren is right,
You are going to out grow a little tractor FAST, so unless you plan to trade up fairly soon, you better aim higher!!! If you limit your self to a 4 foot rotary cutter (brush hog), you will wish you had bought a bigger tractor as soon as the "new ness" wears off!! I wouldn't even consider a BX.
If you want to save some money, get a gear drive trans., it puts more HP out the PTO than a same size hydro, and once you get use to it, you won't care that you have to shift it!
Personally, i'd be looking at 35 to 40HP Ag. tractors. They come with things you will be paying more for on a compact, and they will take a lot more abuse, and out last a compact easily.
BTW, you "can" buy a rear mounted snow blower that you pull. Yes, you drive through the snow, and then the blower picks the snow up, and blows it away. They are a very well built blower, and you can leave your loader on while you are blowing snow! They come in many sizes, even big ones for Ag. tractors.
Robert
/ Tractor Buying Advice #28
Ira:
I mow my 3 acres with our TC29 and rear mount mower on R4's. It works just fine, even around the obstacles. For FEL work you might want to consider The R4 tires though.
/ Tractor Buying Advice #29
I really like my NH TC30. It does well in all I ask it to do.Cost of tractor alone was $10,600. Not a bad price in my humble opinion.
/ Tractor Buying Advice #30
I've enjoyed the discussion on how best to clear snow. I had a snowblower and traded it for a angleable blade for the loader arms. It is much faster and doesn't create a snow storm by blowing quiet fallen snow back into the air.This is a small version of how the commercial companies clear roads and parking lots.Snow blowers and cute, but ....
For what it's worth. -David-
/ Tractor Buying Advice #31
I went to the Kubota dealer and got the following pricing.
For the BX2200, with the 60 MMM, and FEL, total price was 12500 before taxes. For the L3000, with the 400A FEL, and a Woods 6 ft RMM, total price is 15747. This includes turf tires on the L3000 ( thre was a minor charge for these).
Does this sound like a 'good' deal.
Thanks for the advice guys, keep it coming, as I am still learning.
Ira
/ Tractor Buying Advice #32
Ira,
Comparing the L3000 and the BX 2200 is like a Ford F350 basic vs a F150 XLT. Both will get the job done, it's your needs and application that determine what you should buy.
The L3000 is a HD, Gear driven, workhorse, and the BX2200 is a medium duty, hydro static machine. The BX is more refined and the L3000 is a basic CUT, but a very good one with lots of history and fundamental engineering applied.
Price wise. the BX is about right and the L3000 a bit high. Also, you might want to register and put some info in your profile to get some more informed feedback.
Carl
/ Tractor Buying Advice #33
I am quite happy with my New Holland TC30. 30hp, hydrostatic drive, four wheel drive, turf tires, loader and heavy duty bucket for $15,100
Jerry
/ Tractor Buying Advice #34
SethO, IMO. Our properties are almost identical. Except maybe I'm in Northern NJ where rock and hard trees rule. I will buy a tractor this year, and the BX was very attractive. The local rental shop (Kubota dealer as well) finally gave up with about 10 people on the fence about the unit and rented it to me (1st one). I was very disappointed. Not that it's not agreat machine, just not for me and what I need it for. Backhoe had a very hard time budging 2" stumps, large rocks, etc... Loader was better but still took a lot of effort to load full, and then strained at that. Overall, I will pass on it and am now looking at JD4300's, L3010's, NH TC33's, will rent one soon. Seems to me the JD spec's out much higher than the competition but at a price. Nothing in this world that is good, is free or easy.
ChrisNJ,
I looked at the others too including the JD4000 TEN series and the NH tractors, but I concluded that since the most use of the tractor is mowing, I need one that is not too rough on my lawn. Regarding other jobs, a compatible BH for the JD and NH adds substantially more to the price, and if I need to have a big stump removed, I can always rent a big unit, but for the medium jobs it is nice to have one available.
/ Tractor Buying Advice #36
As a BX22 owner, I have to say that I agree with what the tractor's target market is which is an all-purpose *RESIDENTIAL* tractor at a specific price point. Sure there are more powerful and larger tractors out there...by the dozens! But bang for the buck there is nothing on the market that gives you this many features in the mid-$ 16K price range in a brand new high-quality machine.
As my no-bull dealer told me, you can do anything on the BX22 that you can do with the larger tractors, it will just take a little longer. I agree with that statement completely. I can tackle 8" stumps with the backhoe, but I'm not going to pop them out in one or two passes. It takes some digging around and some time to get them out, but it sure beats the alternative which was to leave them in or call in a pro. FEL strength? I moved 12 tons of Chesapeake River Rock with mine the other day from my driveway to under my deck. Sure I may have had to back out of the load a smidge, but each scoop was a full scoop and my alternative was a wheelbarrow and my back before I bought this unit.
Most of us BX22 owners are coming off Lawn or Garden Tractors, and this is a quantum leap from those units in every measure, including convincing the wife you want to spend $ 10K more for this orange machine than what a decent John Deere Garden Tractor costs.
As a mower I don't think you can beat it in a tractor format. You'd have to get into dedicated Zero Turns for a superior unit that cuts this nice and is this stable plus easy enough for a twelve year old to drive. Having the FEL and Backhoe is perfect for the homeowner jobs you come into that you've been doing all these years with pick and shovel.
It's not a tractor that is designed for speed of moving material like the big boys, rather it gets you all the quite capable goodies and still out the door at less than $ 17K. For myself with 5 acres total, and 2 to mow, it's just the ticket and I've yet to find myself wishing I had bought a larger tractor.
-Duane C.
/ Tractor Buying Advice #37
dr
very well put!
If people would only realize that capabilities of a small unit are the same as a big unit and the same things can be accomplished, just in different time frames.
Ron
I took delivery of my BX22 over the weekend, and found that it is every bit as good a mover as a ZTR that I had used earlier for the same lawn. Good stability, nice groomed cuts, incredibly small turning radius for a tractor. Then I went onto the trail and got dirty, with the low range and 4 WD I was fine, and this was after a storm that dropped 7 inches of water on central Wisconsin.
All in all, for anybody who is not a farmer, I will suggest that one takes a serious look at the tractor.
My adventure continues.
Seth
/ Tractor Buying Advice #39
is you'r a 2002? I was just quoted a price of $16,5 for a 2002 NH TC30 w/ a Woods 5' brushhog and a Woods 6' RD mower. Think I should pay less?
/ Tractor Buying Advice #40
Jerry: what do you do with yours? I'm thinking of buying the exact same thing to mow 5 acres and brush hog 10 acres a few times a year. Are you happy, or would you change anything?
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
YARD MULE (INOPERABLE) (A63569)
YARD MULE...
