Buying Advice tractor buying advice please
/ tractor buying advice please #1
Victoria Bell
I need to buy a 30?? horse tractor with a loader for use in spreading mulch (a couple of dump truck loads per year), general dirt and rock work on a farm/garden. I've been shoveling all this, but age is creeping up on me, and it's time to make the tractor buying leap. I've been looking at the Chinese brands, and they look good, the price looks great. My family swears by Kubota, but they're expensive. My question, are Chinese tractors built well? Would you recomend saving a few more years and getting the Kubota? Thanks, Vicki
/ tractor buying advice please #2
The only drawback to "some" of the Chinese tractors is getting service work done on them. If you are near a reliable dealer with a good mechanic you will be "ok". If that isn't the case and you aren't able to service it yourself, save for a different new tractor, or look for a good used one.
/ tractor buying advice please #3
As a Jinma Dealer / Importer.
I have had good service out of the ones I have sold but, I go over them from one end to the other and it has paid off. Someone has to do it.
Purchasing assemblied does not mean it has been serviced properly. That where you have to do your home work.
Your selling dealer is key ... my opinion.
Ronald
Ranch Hand Supply
/ tractor buying advice please #4
Yep, unless you are willing and able to turn a wrench from time to time for maintenance, and have the knowledge to go thru the thing initially and insure it is set up properly, you should probably look for a good dealer that has been around for a while. Proper setup includes but is not limited to:
Flush and change all fluids and filters(repeated again after initial breakin period).
Check all electrical connections.
Check clutch adjustment(requires removal of front end loader frame).
check all fasteners(repeated during routine maintenance as things do shake loose).
grease all fittings(there are quite a few and this is repeated at maintenance time).
If you are not prepared to do these, a good dealer in new chinese, or perhaps a used Kubota, deere, or whatever with a good servicing dealer nearby would be a better option.
For your described uses, a 30HP sounds a little on the large size. From your description, I would think an 18-20HP or perhaps a 25HP tractor would probably be fine.
My.02
Good Luck
/ tractor buying advice please #5
Getting a kubota does not always mean you will not have problems. My L2800 has it's share but the dealer isn't worth crap. Never knows about Product Improvement Bulletins, even if I give him the number to look up. I bought as cheap as I could and got the service from he11. Look for a good dealer, know roughly what you need and see if he can get something in the price range you can afford. Talking to the dealer will help let you know how helpful he might be.
/ tractor buying advice please #6
For the price of a Kaboota you could buy 2 Chinese tractors with all the extras. :D
My take on buying Chinese is this. If it blows up my luck would be the same if I spent 10,000 or 20,000.... Just the parts are cheaper on the Chinese. ;)
I'm a lead footed hacker and I think anything lasts as long as you treat it should. I'm sure I could distroy a 30K Deere or Kaboota in the same amount of time I ruin my Chinese tractor. Or... Vise Versa
/ tractor buying advice please #7
Make sure that you actually see the loader that the dealer offers. The oe loader on my Jinma 284 is almost useless for loading since the bucket does not tilt up enough (unless carried a dangerous 6 feet in the air) and the load spills out while transporting.
/ tractor buying advice please #8
I think a Jinma 254 or 284, same tractor, will do everything you want it to do. I replace a 35hp 2 wheel drive tractor with a 254 in 2003 and now have 425+ hours on it and it has never not ran when I needed it too. Its had a few small problems like thermostat, oil pressure sending unit, but nothing major. I would get a Koyker loader on it and you will be happy. With what the others have said any tractor can have problems but as long as you can do minor repairs to cars you will be ok with the these tractors. Make sure you get a well assembled unit with all the flush and quality oils done and this will make it a turn key experience for the most part. I was like you but I wanted a New Holland TC29 and it was 2x as much. I had the same mind set as others where I figured I could buy 2 for that price. I would do it all over again.
Chris
/ tractor buying advice please #9
Foton from Rural King.
If you have some mechanical ability and are willing to do self repairs as needed Foton is the best cheap tractor on the market.
I have 2 both from RK.
/ tractor buying advice please #10
Vicki,
If you are close someone on our small but growing list of dealers, you might want to look at an AgTrac with the synchro-shuttle transmission. a little more than a jinma, foton or KAMA, but much easier to drive and operate due to the easy shifting. I have sold tractors made by all of the currently popular chinese factories and the reliability and I personally would place the DF made AgTrac tractors at the top of the list. To get a nicer tractor you will have to move to Korean made brands and the price goes up quite a bit. You can see our dealer list at Dealers
/ tractor buying advice please #11
IMO, people focus too much on what they're buying and not who they are buying it from. Many, many years ago a local clothing store that sold, among other items, furs (it was a long time ago), had as its slogan, "If you don't know your furs, know your furrier." The same applies to tractors and probably most other big ticket items. If you don't know tractors, know your dealer.
If money is the issue, I suggest looking at what kind of used, major brand tractor from a good dealer you can get for the same money as a new Chinese tractor.
Shop all your local dealers and tell each one the same thing, i.e., what you want to use the tractor for. Do not tell them you want to 30 hp tractor with a loader. This is to see what they recommend. Also, don't tell them how much you have to spend. Compare all the recommendations, then start worrying about price. You are about to spend a lot of money, you should not rush the decision.
When you're at the dealer;
Check out the service area. Is it clean? Are the mechanics working? Does it look professional? Or are people standing about drinking coffee and talking? Do the mechanics wear uniforms or are they dressed in jeans and T shirts? See any trucks and trailers owned by the dealer indicating they do pick up and delivery? How many of them are there? Big enough to handle your size tractor?
Check out the showroom/sales area. Clean and neat or a pig sty? Some manufacturers have dealer awards for sales and/or service. See any hanging on the wall? Are there empty desks in the sales area? If so, why are people leaving? Do they sell attachments? If so, are they major brand name attachments or no name ones? Some major brands have dealer requirements such as stocking a certain number of models and parts to fix them. If (fill in the blank of a major vendor) is willing to trust these guys, they are probably OK.
Does the place look busy? Not so busy that you're ignored, but busy enough to know that other people trust and like the place.
Walk around the outside. Is there used equipment for sale indicating recent trade ins? Is there a good selection of new tractors and attachments? Are some of the new tractors equipped with a FEL so you can see how they look and try them out? Do some of the tractors have attachments on the three point hitch so you can try them out as well? Is there a paved, grass and dirt area for you to test drive the tractor? Will they loan you a tractor to try out on your property?
Check out the Parts Department. Lots of shelves of parts behind the counter? If not, you may be waiting if you need one. Check the shelves on your side of the counter. Are there any? Bolts, nuts, paint, oil, pins, i.e., the odds and ends and consumables a tractor needs.
Does the dealer sell other things, e.g., Ag tractors or other large farming equipment, lawn and garden tractors, chain saws, string trimmers, things that indicate the dealer is a thriving business. This can also be a problem, i.e., the dealer is a jack of all trades and a master of none or that they concentrate on their large farmer customer base to the detriment of their other customers.
Does the dealer have separate departments for each line (Large Ag, Compact, Lawn and Garden) of equipment they sell and service with separate service trucks?
Check out their web site, assuming they have one. Professional looking or are the Copyright dates still 2003? Send them an email via their web site. Get a response?
Call them on the phone. Get a cheerful receptionist or Bubba back in the garage. Or do you descend into a phone system never to emerge? How many times does the phone ring? Do they have toll free numbers?
Do they take credit cards? Do they offer local bank financing?
None of these things are fool proof. Mechanics can wear uniforms and still be incompetent. People can be friendly and still give you a raw deal. Just some things to think about as you visit each dealer. All of these things help you form an overall opinion of the dealer and what kind of support he will provide.
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
2021 CATERPILLAR 306CR EXCAVATOR (A62129)
2021 CATERPILLAR...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
LandHonor LHR-UBF12 12in Utility Blower Fan (A60352)
LandHonor...
