Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,321
Now that I see how both QAs work, I can see a couple of differences between the SSQA and the European style QA. They are quite different in the tolerances required to make them fit and the way that they wear.
The SSQA uses hardened bevels fits on both the top and bottom connections to the bucket. Those bevels - always under compression by the over-center levers and large compresion springs means the SSQA continually tries to tighten up the bucket connection to the loader as you use it.
Instead of wear amplifying critical clearances, wear on the SSQA type QA actually makes it fit better.
The European style QA uses simpler parts to fabricate and can be easily be made to be very strong, but requires exact assembly and doesn't self-compensate for wear. I wonder if they begin to rattle when they get older?
There are probably other QA systems as well - each with it's own set of advantages. I know that JD uses a proprietary system but I haven't looked into it.
rScotty
Deere uses the Euro quick connect for their larger machines.
On the smaller machines, they use a proprietary one that is essentially Euro style top hooks with a 3/4" pin that a pin (like a 3 point lower link latch pin) goes through.
Aaron Z
/ Tractor backhoe - homemade #1,322
Aaron Z
According to Euro standard its 20mm, not 3/4" (19.05mm)
I wanted to make central locking, but i'm pretty fine with two pins with circlips.
Finally tested with the bucket, works great :). Now back to the backhoe project...
/ Tractor backhoe - homemade #1,324
First time I seen stiffeners on inside of bucket, dont think I would've done that, now add on some bolt-on bucket teeth.
/ Tractor backhoe - homemade #1,325
After following this thread all the way through I don't think I would try to tell this man how to do anything. He appears to be plenty capable.
/ Tractor backhoe - homemade #1,326
Stiffeners are pretty common on larger buckets. This one must be around 7-8 ft wide.
/ Tractor backhoe - homemade #1,327
This! BFreaky, you da man, very impressive.
The bucket is 2.1 meters wide, 0.8 m deep and 0.7m high. Thank you, I try my best
/ Tractor backhoe - homemade #1,329
Now look what you done, you forgot about your old neighbors across the pond, I now have to go find out what a metre is........:hissyfit:
/ Tractor backhoe - homemade #1,330
I got it, your bucket is 6'-10-11/16" wide, OD, almost 7', that a good size bucket now let me see it with bucketful of dirt at full height...........
Oldpath, I will take a picture as soon as possible. It lifts everything I tried, and I tested it with 1.5 tones.
Anyway, after a long while I'm back on the backhoe project. Pins and bushings and boom alignments
/ Tractor backhoe - homemade #1,332
Gee thats strange just the other day I was thinking about your FEL and backhoe build, wondering did I miss the conclusion, 1.5 ton or 2500lbs, thats quite a lot. Everyone here enjoys your build project thanks for posting when you can:thumbsup:
Yeah, well I was quite bussy doing other things, so BH was put a side, but now I will push it till it's done.
Gotta love these plasma cutters, I cut this bevel in no time. It would take like 10 minutes with grinder...
It's not Hypertherm, this is WTL Cut 100 CNC, cuts 45 mm thick steel, torch is the same as Hypertherm.
/ Tractor backhoe - homemade #1,339
Shush, never tell about tool prices...his woman might be reading over his shoulder. :)
Especially since the fridge has be acting up lately and has been to small for the past ten years...
/ Tractor backhoe - homemade #1,340
45mm steel.............:confused2: Glad I have this site in my saved section now I can understand you across the pond folks.... Convert mm, cm to fraction or decimal inches (in = mm = cm)
What you didn't think I'd look up the tools your using, I always do just to know whos doing what with what and how, its a form OCD........
Impressive 45mm=1-3/4 and its cheaper then the Hyper by more then half so theres still some left over for a new fridge so to avoid a frypan over the head.......
WTL CUT 1 CNC Plasmaschneid Inverter
My son bought a Eastwood, figure since he makes some good movies the plasma might be good, well IMO it's ok-ish............
2012 Kinze 3600 Planter (A63109)
2012 Kinze 3600...
159120 (A60430)
159120 (A60430)
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
MISCELLANEOUS TIRES (A63569)
MISCELLANEOUS...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
