Tractor backhoe - homemade
/ Tractor backhoe - homemade
Looks great. How many hours does it have?
/ Tractor backhoe - homemade #1,082
2400.
Not much. Works good? Any flaws?
/ Tractor backhoe - homemade #1,084
Works great. No flaws with the machine. Flaws in the design is is I wise the boom could dig closer to the machine.
Bad geometry? That's why I'm gonna make tripple boom. I had a problem with small height of the bucket close to the machine on my rk 525 so I will make it better on my new one. Some of these details come to attention once you start working with the machine. There are many small details like this one but they do make a difference especially when you work in tight place or next to a building. I figured out I have enough digging depth but can always use more lifting power and height...
/ Tractor backhoe - homemade #1,086
I think it’s more the nature of the beast and less of a design problem. I don’t see any good way to design it better without comprising something else while remaining 2 stick. How much weight do you plan on lifting with the boom and how high can it go?
There are some solutions even on 2 stick machine. The plan is 1000 kg, reach 6 meters, height 7 meters. Digging depth will be 4 meters because we have alot of gravel below the soil so when you dig a deep hole it tends to collapse...
/ Tractor backhoe - homemade #1,088
Why such a massive boom for the tractor it’s going on? The boom on my full size backhoe is rated for 17 feet 8 inch reach and 10 feet load height although I think it would do higher. Maybe it’s not important to you but I think you’re really comprising your possible digging strength with a boom that big. The limitations of my machine is in most cases pulling the machine around or lifting if off the ground. When digging you have to use most of the force to lift up, not pull back and even then it’ll pull the front of the machine out the ground.
The boom is actually not heavy. I made significant difference in material thickness to decrease the weight of the machine. Reach is only little longer then it was on rk 525. I plan to use it for digging and also forest work, loading logs etc.
/ Tractor backhoe - homemade #1,090
You might get more than 1000kg lift on the boom if you have enough weight on the front. This block is 30 cubic feet of concrete so nearly 5000 pounds and it lifted it at 3/4 reach. It lifted the smaller 12 cubic feet each blocks at full reach. IMG_1052.JPGIMG_0927.JPG
Picture of rk 525 lifting 1.1 meter dia concrete pipes at any reach with no problem. I never really measured it's max lifting capacity because it lifted everything i tried to lift. I expect more from rk 600 because main lifting cylinder will be placed under the boom. This way I get 5 tons more dead lift capacity because cylinder is pushing, not pulling the boom
/ Tractor backhoe - homemade #1,092
That’s definitely the stronger way to do it although keeping the machine in the ground is the weak link of my 310.
Grab full front loader bucket of soil to make better ballance...
/ Tractor backhoe - homemade #1,094
Your workmanship is simply amazing.
Thanks. Not sure which part you mean? ;)
/ Tractor backhoe - homemade #1,096
All parts. Design, workmanship, attention to detail, fit and finish, paint. Those kinds of things.
/ Tractor backhoe - homemade #1,097
Then I'm guessing that shallow well is about 12 feet (4 meters) deep. I've done a number of such wells for everything from drainage to irrigation to household use. They work especially well when you can intercept a gravel layer at depth. What is this one for?
rScotty
It's a drainage pit and you guessed it's 4 meters deep. We had a problem with water collecting on the road during heavy rains so this solved the issue completely. I went to maximum depth with rk 525
/ Tractor backhoe - homemade #1,099
I've done a number of those that work as irrigation wells in the dry season and as drainage wells during sudden water events. The trick is to get an open bottom into the water-bearing gravel layer. That way the same well can store water over a large area to draw on later.
rScotty
New homemade backhoe excavator project in progress. Stabilzer tubes and sideshift frame build
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
3 Brake Drums (A62613)
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
Caterpillar 322 Excavator Service and Parts Manuals (A63117)
Caterpillar 322...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Ford F-450 (A63689)
Ford F-450 (A63689)
