Tractor backhoe - homemade
   / Tractor backhoe - homemade #851
Eric, I'm not trying to hijack anything, I'm trying to ask one of the only two blokes I've found who can speak from their own direct experience. If Bfreaky was still in construction phase you would have a fair point, but his build was complete back in June and there is no ongoing activity on this thread. Bfreaky, I'll leave this to you to determine, I certainly had not intended to distract from your brilliant project. Angus
Angus not trying to be rude; I apologize if it came across this way.
Just saying that you could still ask BFreaky the question in a new thread as TBN members would like to follow along including me.
Maybe DM BFreaky and have him reply to your new thread?
Just a suggestion
Sent from my iPhone 5s 64Gb using TractorByNet
   / Tractor backhoe - homemade #852
Just a suggestion
   / Tractor backhoe - homemade #853
Yes; I've finished the swing cylinders, mounted them in place and tested the swing motion. It works great. Btw, as far as I'm concerned, this is the most complicated part of the machine and it took a loot of thought and drawing.
Hydraulic thumb is also finished...
Hi BFreaky, how did you weld the trunnion union onto the cylinder, by avoiding that the welding retract the cylinder diameter?
I would like to make the same cylinder for a wood splitter, but I'm afraid to retract the cylinder after having welded. Preventing me from screwing the head.
I love your job onto this backhoe.
Congratulation
You have to remove all the rubber seals from the cylinder because they will melt, screw the "head" in place but not too tight and then first make tack welds on opposite sides. After that weld it around i one movement. When you finish leave the cylinder to cool down slowly, do not cool it with water because your welds will crack
Here's a great example of how a hydraulic thumb can make a huuuge difference when you stumble on a pile of garbage like this one. :)
I picked it all up, no sweat :)
   / Tractor backhoe - homemade #857
Good job. How have you been? Are you married yet? :)
What is your next project?
Yes, I married few weeks ago. :)
I'm fine, thank you. How are you?
Next project...new model of snow/dozer blade. Pieces are already cut
   / Tractor backhoe - homemade #859
Congrats on getting Married, any major problems with the Backhoe?
   / Tractor backhoe - homemade #860
Nice, looking forward to seeing the new build. Oh yeah, congrats on the married part. :)
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
(3) METAL & WOOD SHELVES (A58374)
(3) METAL & WOOD...
