tracked vihicle
/ tracked vihicle #1
jakedory
thinking of building a 6x6 tracked vehical any one who has done this would like your imput
/ tracked vihicle #3
Hello & WELCOME to TractorByNet.com! :)
I moved your thread to the Build-It Yourself Forum.
/ tracked vihicle #4
Rigid axles to body or suspended?
/ tracked vihicle #6
What is your budget or access to auto parts? What will you use it for? Does it need to float? Do you have a year to work on it? Typically you will need the open front diff off a independant suspension 4x4, Japanese mini trucks will have lower gear ratios. You need to move disc brakes inboard for braked steering then short CV shafts to your drive wheels. ATV Tires allow you to pump up the tires to hold the tracks or else you will need a track tensioning system added. Sounds like a neat project.
/ tracked vihicle #7
Things will also work better if your drive (cog) wheels are in the rear to keep the tracks tight under load....
Just noticed you said 6x6, do you plan to drive all 6? Like an Argo? I would build with 6 ground wheels plus a rear drive axle that is slightly elevated. Don't know how big you are planning to go however...
/ tracked vihicle #8
Here are two of my favorite tracked builds lately from TBN...
http://www.tractorbynet.com/forums/build-yourself/170738-my-ride-tracked-dumper.html
http://www.tractorbynet.com/forums/build-yourself/157345-mini-dozer-project-near-complete.html
Also, I think it was David Devuano that build a wheelbarrow type tracked dumper a long time back. The track was pretty clever. If I remember right it was link chain with U shaped metal cleats welded to every other chain link (or so). Think tire chains on steroids. If it wasn't you David feel free to call me a liar.
/ tracked vihicle #9
What is interesting is the US Army (ww2?) Weasel also used chain links to connect the steel track pads. If you are looking at my tracked wheel barrow on Ytube, note that I would build more wrap around the tires and use solid rubber at the front. There are hundreds of homemade tracked vehicles on Utube. Some of the best are found under 3/5 scale tanks. A really simple to build tank transmission is also found which I might consider in any future builds.
/ tracked vihicle
thanks for all the info .the things that help to a good start some things i havent given much though to.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
