TPH Direct Drive Winch Project
/ TPH Direct Drive Winch Project #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
Here is my latest basement shop creation. I needed a light duty winch to pull my submersible water well pump next time it goes out. The submersible pump is 150’ down there is a ¼” nylon rope tied to the pump that will be used to attach to the winch.
On the tractor hydraulic system I have an adjustable flow divider valve; with this I can control the flow to the motor. The Hydraulic motor is 15.25 cu/In per revolution and has 2540 lb/in of torque. ($25 eBay Special) If I set the flow to say 6 GPM the motor will turn @ ~ 90 RPM about one and a half revolutions for every second. The center of the cable hub on the winch is 2” diameter so the circumference is about 6” if my math is roughly correct then the cable speed would be about 54 feet per minuet before the cable wrap starts making the center of the hub a larger diameter increasing the speed.
The winch assembly slides into the TPH receiver hitch (also home made).
I will most likely use the winch for other tasks around the homestead. If I ever do any overhead lifting I will make sure I raise the TPH to it’s highest setting to avoid any supprises.
Any comments or constructive criticism are very welcome.
Here is a side view
Here it the Other side view
Top View
Bottom View
/ TPH Direct Drive Winch Project #6
Very NICE!
I am curious how it pulls? I would like to buuild one,,what kind of motor is that?
/ TPH Direct Drive Winch Project #7
Well...ain't that the purdiest thing!!
Looks great!
/ TPH Direct Drive Winch Project #8
Good Job GuglioLS..... The only thing I see wrong with it is that.... I dont have one !!
Ronald
/ TPH Direct Drive Winch Project #9
Nice job. I'm not good at conversions from things like torque to weight lifting ability; given a proper cable, does that number 2540 lb/in of torque mean it could lift something that weighs 2500 Lbs up out of (for example) a well?
/ TPH Direct Drive Winch Project #10
</font><font color="blue" class="small">( . . . does that number 2540 lb/in of torque mean it could lift something that weighs 2500 Lbs up out of (for example) a well? )</font>
I was also wondering if it means that he can flip his tractor over without even being on it.
Cliff
By the way, that's a clever and well done project.
/ TPH Direct Drive Winch Project #11
</font><font color="blue" class="small">( it could lift something that weighs 2500 Lbs up out of (for example) a well? )</font>
If I could get the mother in law down there in the first place...I sure as heck wouldn't be worrying anout getting her out!!!
/ TPH Direct Drive Winch Project #12
Nice work. There are a couple things I wonder about.
Since the rope will be feeding up onto the spool from the casing, it will likely want to wrap around a narrow spot on the reel. Something similar to the guide on a fishing reel to traverse the spool and distribute the rope may be helpful. I picture the rope wanting to stack itself at one place on the spool till it kinda "falls over".
I have used real rope winches, and they don't accumulate the rope. The spool (aka capstan) has a curve that accepts the rope as you pull on it. The rope feeds onto the larger part of the curve, and that pushes the rope you are pulling on to the smaller diameter part of the capstan. This (as long as the load provides enough tension) prevents the rope from wrapping on itself. Since the rope is only being pulled by the friction caused by the load resistance and the tension you provide, the pull can be stopped, or speed varied even though the RPM's are constant. If you go to greenlee.com and check the cable pulling section, you can see better what I'm trying to explain...................chim
/ TPH Direct Drive Winch Project #13
</font><font color="blue" class="small">( Since the rope will be feeding up onto the spool from the casing, it will likely want to wrap around a narrow spot on the reel. Something similar to the guide on a fishing reel to traverse the spool and distribute the rope may be helpful. I picture the rope wanting to stack itself at one place on the spool till it kinda "falls over".
)</font>
As long as there is enough distance from the top of the casing to the winch for the rope to move back and forth , the rope should wind itself nicely in layers. Aircraft cable does this on the winches I've worked with, as long as there remains tension on the line. Only when the rope is fed rigidly on one spot on the spool will it "stack up" on itself.
Those capstan winches from the Greenlee catalog are nice, too....don't have to worry about starting and stopping the winch, just keep a steady pull on the rope, and here comes the load! </font><font color="blue" class="small">( )</font>
/ TPH Direct Drive Winch Project #14
54' a minute is kind of fast for a winch. Of course, you can reduce the speed with a snatch block. May work better as a windlass for your application of pulling the sub-pump.
Don't forget the fencing application; rolling up barbed wire.
And, I'd pass on the overhead hoisting applications. Hoists have a brake on them for safety.
Thanks for the many replies –
I will try to answer all the questions in order
<font color="blue"> </font> Buzz_Sawyer
<font color="blue"> </font> “I am curious how it pulls? I would like to build one, what kind of motor is that?” <font color="black"> </font>
I installed a 100’x 3/16” cable on it today and pulled the 6000# tractor up a small slope no problem. The Motor is an Italian made META brand similar to White Hydraulics Motor # RS14040100 it is 4 & ½” bolt circle 3&1/4” Pilot Diameter, 1” keyed shaft # 10 O-ring ports 15.25 Cubic inch per revolution 2540 lb/in of torque. Found it on eBay for a “steel”
<font color="blue"> </font> Mike_C
“Does that number 2540 lb/in of torque mean it could lift something that weighs 2500 Lbs up out of (for example) a well?” <font color="black"> </font>
Yes, I did some homework on torque and sure enough 2540 lb/in of torque will pull 2540# of stuff in any direction. In fact I did a “little” test just to prove it to myself.
I hooked the cable to my overhead chain hoist and with the hydraulics lifted the whole darn rear end of the tractor 2 feet off the ground. Sure enough as hobbyfarm suggested it did not stay there very long as when I released the valve the tractor returned to the ground as the spool unwound – the motor will not hold when idle so the direct drive is not that great or safe for overhead lifting. A worm gear and higher speed motor would be much better for that type of application. But for what I want to do – horizontal pulling & pulling out the well (about 250 lbs) 20 feet at a time it will work very well.
<font color="blue"> </font> Cliff_Johns
“I was also wondering if it means that he can flip his tractor over without even being on it.” <font color="black"> </font>
This is a possibility – however I think that the cable would break first. And if not it would be in very slow motion (Famous Last Words). I will be careful.
<font color="blue"> </font> chim <font color="black"> </font>
Point well taken – after some experiments today I did find that at a minimum I will need to add some sort of tensioning device to put pressure on the cable / rope to keep it from unwinding when not in use. There was no problem of the rope winding on top of itself as I can guide the rope by hand. Were only talking about 150’ of ¼” nylon rope to pull the well out. The well casing is 1’ above ground and I can get the TPH about 3 & 1/2’ above it so I have lots of room to guide it on the spool.
<font color="blue"> </font> hobbyfarm
“54' a minute is kind of fast for a winch. Of course, you can reduce the speed with a snatch block.”
<font color="black"> </font> I found the speed to be just about right it is not that fast – I can control the speed with the adjustable flow hydraulic divider already on the tractor in addition to “feathering” the control valve at the motor.
<font color="blue"> </font> “Don't forget the fencing application; rolling up barbed wire.”
<font color="black"> </font> Yes thanks !!!!! I have lots of fence and need to pull more.
<font color="blue"> </font> And, I'd pass on the overhead hoisting applications. Hoists have a brake on them for safety. <font color="black"> </font>
After my “little” experiment I will NOT be using it for overhead applications only the Horizontal or “underground” ones i.e. pulling the well, logs, fence etc.
Thank you all who replied.
Larry
/ TPH Direct Drive Winch Project #16
Larry, you are the king of the 2" tube accessory market! I get a real kick out of all of your creations. Great going! Can you adjust the speed with a hydraulic flow control of some sort?
/ TPH Direct Drive Winch Project #17
</font><font color="blue" class="small">( Larry, you are the king of the 2" tube accessory market! I get a real kick out of all of your creations. Great going! Can you adjust the speed with a hydraulic flow control of some sort?
)</font>
Larry,
Ditto, what Tim_in_IA said. The winch is a cool device, and I'm sure you'll find many uses for it. I'm sorry I got side-tracked about the safety of using it as a hoist. I didn't want to see anyone get hurt.
BTW, I think it'd be cool if you mount it to the front of the tractor too (you never know when you'll need to pull yourself out of something). Maybe with a receiver hitch?? adapter. /forums/images/graemlins/smile.gif
YES I can control the speed with the VARIABLE Flow divider that I installed on the tractor before I installed the FEL.
AND OR I can control the speed by feathering the valve, these valves are good for feathering.
Here is a PIC of the variable flow divider.
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
