Towing Question??
/ Towing Question?? #61
I weighed my 96 F350 long bed diesel crew cab shortly after getting it.
7700 lbs total with 200 lb me and two kids weighing at the time maybe 200, so 7300 lbs. Ford showed it at 6400 on the shipping docs IIRC.
I now have a metal utility top on and carry a bunch of tools, a winch out front etc, best guess now is almost at 10,000 empty with the now 250 lb me in it. This is based on scale weights at a quarry I pick up rock at with a trailer that supposedly weighs 3500, I scale in at around 13,500 and leave at 23,500.
I'm glad to hear of the OP using a stronger trailer, never hurts to be safe IMO.:thumbsup:
/ Towing Question??
In the military for almost 33 years, number one priority is safety. We will post pictures of doing it right I hope.
Eddie
/ Towing Question?? #63
Normally anything over 5 tons must stop at weigh stations, but I've seen some bypass the scales and get away with it............I've also seen others pulled over less than a mile after running a weigh station.
That means every 5th wheel camper out there must stop and get loaded. I pull 18,000# plus all over the place and never stopped at a scale one single time. Never been chased down either.
As for the guys tires blowing, what brand? Carlisie and Goodyear Marathons are pure junk in my opinion. I had had both just blow for no reason. Now only sell and use Maxxis, Greenballs, and Hercules.
My 2006 F-350 SRW 4x4 short bed extended back with a diesel weighs 7,600# with me in it and 3/4 tank of fuel. I have no tool box or anything in the bed and maybe 30# of tools under the rear seat.
Chris
/ Towing Question?? #64
Since this kinda is the un-offical truck weight thread, I though I'd share mine.
I hauled some scrap in today. FULL tank of fuel and me (165lbs) and the truck weighed 7870. Maybe a few empty beer cans and a few ratchet straps in the bed was all.
It is a 2005 Dodge 3500 4x4 DRW long bed w/5.9 cummins. So with a 12,200GVWR, that gives me a 4330lb payload capacity. I can live with that. Allthough I was expecting a weight closer to 7500-7600 with just me.
/ Towing Question?? #65
Wow, that seems light.
My '01 F-350 is a 4x4, regular cab, flatbed dually with the 7.3 PowerStroke. Weighs right at 8,000 pounds 'empty' with a full tank of fuel and me in it. It was 7,900 before I put the toolbox on.
GVWR is 12,500 on mine.
/ Towing Question?? #66
You think my 12,200 gvwr truck weighing in @ 7870lbs is light:confused2:
When your 12,500 Gvwr truck only weighed 7900lbs. And that is with a V8 diesel???????
What do you think it should weigh?
/ Towing Question?? #67
Well, not the second time I read it. :laughing:
The first time, I thought it said you had a crew cab. That's where my confusion came from, I couldn't figure out how Dodge managed to fit a bunch of extra sheet metal and interior, and weigh a bit less than a 2 door Ford. My mistake. :ashamed:
The crew cab, 4x4, long bed DRW F-350 I used to have weighed somewhere around 8,600 lbs if I recall correctly. It's been a few years since I had that truck.
/ Towing Question?? #68
It is a quad cab. Maybe I forgot to mention that.
I still think its heavy.
As diamondpilot said, the fords are usually heavier. And I'm sure that flad bed you have on your 2-door is heavier than a regular bed.
The reason I though 7900 lbs was more than I expected is because according to doge's site, the curb weight of a new truck equipped like mine is only 7600lbs.
Dodge - Compare Vehicle and Model Specifications - Highlights
And if you click rhe regular cab 8' bed one, it is only 7100lbs. So the Quad-cab long bed is ~500 lbs more.
/ Towing Question??
Todays update, towed truck to Baltimore, MD. Left Disputanta, VA (below Petersburg, VA) at 3:30am this morning, arrived in MD at about 8:30am. Took our time (55-60 mph), stopped a few times to check straps and chain. Stopped once for breakfast. Not one issue at all, the Cummins performed flawless. Only downshifted two times for entire trip. Towed over 10,000 lbs today and I was impressed. I borrowed a larger trailer (5 ton) to make this trip. I have some pictures attached of the way we strapped trailer to truck. Private owner trailers don't have to stop at weight stations.
By the way got 13.39 mpg for entire trip, loaded up and emply trailer on return.
Thanks for all the Comments!!
Eddie
/ Towing Question?? #70
Glad it went well. Did you hand calculate the fuel or use the dash? I take it you also got a heavier trailer to use for the trip.
Chris
/ Towing Question?? #71
Chris
ditto that.. I've had my 14k rated gooseneck all over florida, georgia, mississippi, lousiana, alabama and texas. I never stop at scales, and have never been chased down.
soundguy
/ Towing Question??
Fuel was hand calculated. I was impressed with the fuel mileage for my Cummins. I was able to borrow a 5 ton trailer from a trailer owner in Petersburg who let me use one that had been returned for a larger trailer. Probably saved my friend about $750.00 to get truck to tranny shop.
Eddie
/ Towing Question?? #73
I bet you could pick up that trailer with the truck strapped down, turn it upside down and it still wouldn't move. Certainly tied down well! :thumbsup:
/ Towing Question?? #74
I agree. Almost over kill but hey, nothing with going the extra mile to get that bow-tie to the shop.:laughing:
Chris
/ Towing Question?? #75
Don87,
You should have removed the forks and turned the forklift sideways when loading. Most forklifts used in wharehouses will fit and it keeps them from rolling either forward or backwards. Too late, but maybe for next time. Your trailer didn't have E tracks? Another way is to use a strap (I have stopped and bought one) anchored on the back bumper and run into the trailer (doubled) and secured a moveable object. Close the doors on the strap.
Good luck with the freight claim.
David from jax
The forklift I was hauling was too big to turn sideways in the trailer.
/ Towing Question?? #76
Chris
DOT never messes with tourists...............It's a no-no, so I'm told.
/ Towing Question?? #77
Eddie
I'm glad you found a different trailer. I'm also glad you made it there with no problems.
I have seen times where the DOT pulls over pickups that appear to be overloaded. I've also seen them escorted to the scales by a DOT officer.
And as you stated earlier.....It's all about safety:thumbsup:
/ Towing Question?? #78
down here we like to refer to it as revenue enforcement. and heck.. if it happens to promote a lil safety while they drain your wallet.. it's a side effect they are willing to work with...
soundguy
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
iDrive TDS-2010H...
