Towing a trailer
/ Towing a trailer #41
If a fan "pushes" air from the engine compartment outward through the radiator, it would be drawing warm air from around the engine instead of cool fresh air from outside; disadvantage. On the other hand, it would plow dust and grass away from the grill and outside of the radiator instead of of sucking it into it; advantage. Now which is best? I have no idea. But I do know that the only time my temperature gauge gets to the halfway mark or above, I need to stop and clean the debris off the front end.
/ Towing a trailer #42
9N Fords blew, 8Ns sucked. People are still argueing which is best 60 years later. I guess if you wanted to you could have a puller for the winter and a pusher for the summer. Ditch the crank driven fan and install an electric fan with a reversing switch. When the radiator plugs, reverse the fan. When you're cold, pull the air. Get a little hot, reverse it. I might try it someday.
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
New/Unused 20ft Metal Farm Driveway Gate (A65583)
New/Unused 20ft...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Frontier RT3062 (A64126)
Frontier RT3062...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
