Towed Tractor Rollover
/ Towed Tractor Rollover #41
This has been a great thread. I've never had any towing problems probably because I load correctly and stay on the back roads at a slow speed. Today, while towing I paid a little more attention and have a question. I think--but am not sure--that the trailer brakes engaged a bit before the truck brakes did. Is this possible? I have a 2011 Toyota Tundra with the tow package and I have a "tow/haul" mode button that I presumed just lowered the shift point. Not much mention in the owner's manual. Any thoughts?
I have no clue about Toyota but I do know when my brother bought me a new Peterbilt I mentioned to him one day that it felt like the trailer brakes would grab before the trucks did. Apparently it's how they are setting up some of the new trucks now to help avoid jack knifed accidents.
And yes if you start fish tailing a little brake or "spike as we call it" on THE TRAILER ONLY should help pull you straight. Of course if you are on ice NEVER do that or you will most likely end up in an awful mess faster than you can say oh crap.
On ice I have been pushed down hills skidding many times especially if your running jeep and pole setups or jeep and rack setups the minute they go out of line with the truck they want to pass. We have a trick around here called throwing out the anchor. If you know your truck good enough you throw your trailer in the snow bank let it get you back under control and to a reasonable speed then pop it back on the road before you slow to much and end up stuck. This is of course running off road hauling logs and I wouldn't try it on the freeway but you get the idea.
/ Towed Tractor Rollover #42
Yes, I have a brake controller and my trailer has electric brakes .
/ Towed Tractor Rollover #43
If the brake controller is set aggressively, its normal for the trailer brakes to grab first unless you are braking hard.
Aaron Z
/ Towed Tractor Rollover #44
/ Towed Tractor Rollover #45
This is a question for you experienced guys. What should you do if your trailer start fishtailing? I have only very limited towing experience but based on one event while transporting upright piano (high CG) stepping on brake (no hard braking) stabilized the trailer instantly. My guess is that braking removes energy from the system while acceleration would add energy flipping the trailer.
CCWKEN nailed it, hit the gas & pull it out, then slow down as needed. Trailer brakes set aggressively can be a scary experience as well, had a trailer snatch a 1 ton plumb into the opposite lane years ago, after that experience, i checked the setting each time when towing the trailer.
Ronnie
/ Towed Tractor Rollover #46
Trailer Brake Controller Comparison Review Video | etrailer.com
Not all brake controllers are equal. Didn't read the above link real well, but basically there is time delay that apply the brakes in the trailer harder at first. My guess is that is what you are feeling. It is also real important that your brake controller is installed and set up correctly!
The brake controller on our Ford Transit is adjustable. Haven't used it yet because we've only used older, surge trailers.
/ Towed Tractor Rollover #47
/ Towed Tractor Rollover #48
This is interesting b/c I have a 1999 Ford 3/4 ton and a 20' eqp trailer as well as a 24' bumper pull camper. I, too, can feel a bit of a push from semis passing, but no pucker factor. Mine is a CC long bed, so I think that helps. I've heard similar towing horror stories. Maybe I'm just lucky? FWIW, we took the camper all over the USA last summer. Generally ran 70-80 mph. Maybe weight is a factor. My camper is only about 6500 to 7 k loaded up. Also, I use WD hitch on camper but not on eqp trailer.
There were often times I was loaded close to max GVWR or GCWR. An extra set of rear wheels and moving the weight from the bumper to the bed made all the difference.
/ Towed Tractor Rollover #49
Sway is also a function of speed. And the magic number is right around 55 mph where things will exponentially get out of control.
The hardest thing to manage is to NOT over correct the steering on the truck. You want very small slow corrections. Speaking from experience.
/ Towed Tractor Rollover #50
I was always taught to control it very similar to tank slap on a motorcycle. If you freeze up or get rigid it will make it worse, stay loose and fluid and calm and decelerate slowly until back in cotrol.
/ Towed Tractor Rollover #51
My brake controller is adjustable. My 2600 pound trailer needs a lot less brakes than my fully loaded GN. If I forget to adjust the controller after pulling the GN it will lock up the light trailer with very light braking.
/ Towed Tractor Rollover #52
I have had several close calls with whipping trailers. Every time it was caused by having too little tongue weight and I was able to regain control by applying the trailer brakes manually. These incidents were all over ten years ago when I wasn't early as experienced towing as I am now. Now I always make sure to load the tongue heavy. From what I have seen the gross weight of the load has little to do with the whipping it is all about the tongue weight though a heavier trailer can sure jerk the truck around more if it gets to whipping. Heaviest load I have pulled with a bumper pull was around 20k(load and trailer)on a pintle hitch trailer behind my dually and it tracked fine but I had about 2500lb tongue weight.
/ Towed Tractor Rollover #53
I see people pulling 10-15k travel trailers and toy haulers behind half ton trucks all the time.
I put as much distance as I can between my Cummins and them.
One of them jackknifed just outside of town a week or two ago when we had slight crosswinds.
They never learn.
/ Towed Tractor Rollover #54
Somewhat related question. Recently purchased an 18' 7K trailer. When adjusting the brakes according to the manual I could never get them to lock up, even with the gain set to 10 (highest setting).
Am I not hitting the brake pedal hard enough?
/ Towed Tractor Rollover #55
More likely a wiring issue. Brakes not wired right, maybe to the wrong terminal on the plug. Bad ground?
/ Towed Tractor Rollover #57
On a brand new trailer purchased from a large dealer?
/ Towed Tractor Rollover #58
Are they activating at all? Just not reaching the drum? You check for voltage at the truck?
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
100 Gal Oil Container (A64127)
100 Gal Oil...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
