Towable ripper needed
/ Towable ripper needed #1
virgban
John Deere
We have a John Deere model L110 (18 HP) garden tractor and wish to use it to dig some long trenches 1" wide and 3" deep for 3/4" irrigation lines that I plan to drain or blow out in the winter. I watched large tractors with rippers on a 3 point hitch do the job very well, but we do not have this equipment. Does anyone know of a source or a DIY design for a ripper to do this job by towing it (as with a chain)? By towing, this ripper job can be done in stages in case there is not enough power/traction to do the entire job in one pass. Set for a shallow depth for the first pass and 3" for a subsequent pass. I plan to walk behind it and use it like an antique plow pulled by draft animals. The shaft/blade could be very simple since the width is very small. Two shafts, one in front to cut, and one in back to stabilize it would make a straight trench. Any ideas will be greatly appreciated.
/ Towable ripper needed #3
Are you sure you have that model number right? A John Deere model L110 (18 HP) is a low end grass cutter, not a garden tractor. It can barely pull itself and operator and is not intended for any kind of ground engagement. A JD 110 is a garden tractor made in the 1960s or so, but I only see 8 or 10HP models.
Thanks. Our L110 pulled a trailer loaded with mulch just fine up hills so I'm thinking a 3" x1" trench in a grass lawn might work in stages. Might need chains and weight for traction.
/ Towable ripper needed #6
Don't know your location, but renting a trencher for a day may be a better option for you
/ Towable ripper needed #7
this is not a super idea, the transmission on your lawn mower is not built for this. you may get away with it, but it will shorten the life of the hydro. i would consider this on my allis, but i don't think i would even do it on my cub GT. a drag harrow is about all i'm willing to do with that.
/ Towable ripper needed #8
If you go with your plan you'll probably be able to make use of this. https://www.tractorbynet.com/forums...light=Tuff+Torq+K46V+hydrostatic+transmission
Thanks for this heads-up. My son's John Deere L110 will not be used for a high stress volunteer work like pulling a plow. You have provided a strategy for when the hydro fails.
/ Towable ripper needed #10
When i went out to buy a plow for my little iseki, the guy from this company said my mini-traktor (15hp) could support max a 2-ski plow, but he very much advised against this, and said this calculation only works on very soft and loose ground. So i bought this 1-ski plow, and even with that i sometimes get stuck.
I can confirm this puts enormous pressure on whatever is pulling it. It even bended my 3-point connection set.
Also my little iseki looks a lot more like a 'tractor' than your L110 i googled. Don't do it, you'll wreck it i think.
2010 Volkswagen Routan Van (A59231)
2010 Volkswagen...
2018 John Deere TX (A53317)
2018 John Deere TX...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
405 (A52706)
405 (A52706)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
