Towable ripper needed
/ Towable ripper needed #1
virgban
John Deere
We have a John Deere model L110 (18 HP) garden tractor and wish to use it to dig some long trenches 1" wide and 3" deep for 3/4" irrigation lines that I plan to drain or blow out in the winter. I watched large tractors with rippers on a 3 point hitch do the job very well, but we do not have this equipment. Does anyone know of a source or a DIY design for a ripper to do this job by towing it (as with a chain)? By towing, this ripper job can be done in stages in case there is not enough power/traction to do the entire job in one pass. Set for a shallow depth for the first pass and 3" for a subsequent pass. I plan to walk behind it and use it like an antique plow pulled by draft animals. The shaft/blade could be very simple since the width is very small. Two shafts, one in front to cut, and one in back to stabilize it would make a straight trench. Any ideas will be greatly appreciated.
/ Towable ripper needed #3
Are you sure you have that model number right? A John Deere model L110 (18 HP) is a low end grass cutter, not a garden tractor. It can barely pull itself and operator and is not intended for any kind of ground engagement. A JD 110 is a garden tractor made in the 1960s or so, but I only see 8 or 10HP models.
Thanks. Our L110 pulled a trailer loaded with mulch just fine up hills so I'm thinking a 3" x1" trench in a grass lawn might work in stages. Might need chains and weight for traction.
/ Towable ripper needed #6
Don't know your location, but renting a trencher for a day may be a better option for you
/ Towable ripper needed #7
this is not a super idea, the transmission on your lawn mower is not built for this. you may get away with it, but it will shorten the life of the hydro. i would consider this on my allis, but i don't think i would even do it on my cub GT. a drag harrow is about all i'm willing to do with that.
/ Towable ripper needed #8
If you go with your plan you'll probably be able to make use of this. https://www.tractorbynet.com/forums...light=Tuff+Torq+K46V+hydrostatic+transmission
Thanks for this heads-up. My son's John Deere L110 will not be used for a high stress volunteer work like pulling a plow. You have provided a strategy for when the hydro fails.
/ Towable ripper needed #10
When i went out to buy a plow for my little iseki, the guy from this company said my mini-traktor (15hp) could support max a 2-ski plow, but he very much advised against this, and said this calculation only works on very soft and loose ground. So i bought this 1-ski plow, and even with that i sometimes get stuck.
I can confirm this puts enormous pressure on whatever is pulling it. It even bended my 3-point connection set.
Also my little iseki looks a lot more like a 'tractor' than your L110 i googled. Don't do it, you'll wreck it i think.
/ Towable ripper needed #11
Usually small equipment used to bury sprinkler lines have a vibrater built into them to vibrate the ripper. Without the vibrater they aren't very effective.
/ Towable ripper needed #12
come on guys we are talking about 3 inches deep. he is not trying to go 18 inches deep. I say try it but you may run out of traction especially if you have hard ground. try it when it is wet but not too wet.
a trencher would make a big mess if your goal is 1 inch wide by 3 inches deep.
/ Towable ripper needed #13
Next thread. “John Deere mower rear ended busted after only 160 hours and 4 years, such junk”
Thanks, MarcelPL. I agree.
/ Towable ripper needed #15
You need to check the outside diameter of your 3/4" pipe, it probably will not fit in a 1" trench. 3/4" sched 40 PVC is just over 1" od, black poly is at 7/8" od and you should lay the pipe in an "s" shape to allow for temperature changes (If you're in the south this may not matter.) In addition, your trench sides are not going to be nice and clean so there will be clumps sticking into the 1" space. You need a wider trench.
/ Towable ripper needed #16
Not that I think the OP's planned plow equipment will work well to begin with, but maybe if they used it behind a car or truck operated very carefully? Or an ATV?
/ Towable ripper needed #17
Years ago I buried an invisible fence wire with a cheap Craftsman lawn tractor. A simple, 2 person rig that could potentially work for sprinkler lines as well. I bought a long steel spud and drilled a hitch hole. Rigged a tow chain to the tractor. One person on the tractor and the other guiding the spud. It was easy to control the path and depth with the leverage of the spud.
I'm sure there are more elegant ways to get it done but this worked!
/ Towable ripper needed #18
New hydrostatic transmissions for JD Tractors (TUFF TORQ) cost $600-$700 (or more) .... Rebuild parts for my L120 was over $400.... Some of you people don't realize how much resistance 3 inches of dirt can be....
Dale
/ Towable ripper needed #19
Forget the riding mower.
Are you married?
Bruce
/ Towable ripper needed #20
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Hydraulic rail grinder (A61306)
Hydraulic rail...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
