Tow / tie-down DK5310SE
/ Tow / tie-down DK5310SE #1
D&D
KIoti, JD, Kubota
I was concerned about pulling on or with the loader so I made up a frame mounted pull / tie-down point. After machining the eye and adding an oilite bushing, it was welded to a piece of 1/2" plate. Attached using 4 new 14x1.5x40mm 10.9 bolts.
/ Tow / tie-down DK5310SE #3
I have a similar setup on my Bobcat CT122.
  • Good Post
Reactions: D&D
/ Tow / tie-down DK5310SE #5
I like it. It's similar to towing from the drawbar, (which is the only recommended tow point for tractors - based on their technical manuals), for obvious reasons, to those with common sense. (y)
It is WAY better from a strength and safety standpoint than bucket hook(s) or using any part of bucket/loader.
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A65643)
2008 STOUGHTON...
Log Chain (A65640)
Log Chain (A65640)
2014 Grand Caravan (A62679)
2014 Grand Caravan...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
