Tow / tie-down DK5310SE
/ Tow / tie-down DK5310SE #1
D&D
KIoti, JD, Kubota
I was concerned about pulling on or with the loader so I made up a frame mounted pull / tie-down point. After machining the eye and adding an oilite bushing, it was welded to a piece of 1/2" plate. Attached using 4 new 14x1.5x40mm 10.9 bolts.
/ Tow / tie-down DK5310SE #3
I have a similar setup on my Bobcat CT122.
  • Good Post
Reactions: D&D
/ Tow / tie-down DK5310SE #5
I like it. It's similar to towing from the drawbar, (which is the only recommended tow point for tractors - based on their technical manuals), for obvious reasons, to those with common sense. (y)
It is WAY better from a strength and safety standpoint than bucket hook(s) or using any part of bucket/loader.
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
8ft Fork Extensions (A64553)
8ft Fork...
JOHN DEERE S690 COMBINE (A64278)
JOHN DEERE S690...
