Tow/Bypass Valve Limitations PT-425 & Perhaps Others
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others
J_J said:
A better word or words would be AUX HYD . You can use it for whatever, a cylinder, hydraulic motor, The aux hydraulic has a small pump, somewhere around of 1.5 to 3 gpm. At least mine does, and this same pump also controls the steering, lift circuits, and aux hyd.
My PT manuals do not show the aux circuit at all, and the illustrated parts diagram does not break down the PTO/Lift/Steering pump at all, but treats it as a single part. I have no idea what the flow rate on mine is. The manuals can be very frustrating.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #42
Sedgewood had links to these files. In a way for me it give a clearer picture of how this pump works.
there are a few things I still don't get, but I want to formulate the questions clearly.
Here is the link to the PDF's as they are too big for TBN
ttp://www.sauer-danfoss.com/domdb/SASproducts.nsf/2dd81f77829d09d086256591004f57d7/5d44424d42f146f9862565d100577a08?OpenDocument
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #43
Isn't the AUX. HYD. /AUX. PTO circuit on the 422 & 425 operated by the lever by your right leg, and isn't that lever attached to the 3-spool SAUER/DANFOSS valve ?. So the flow rate would be what ever the spool valve is set at (pressure & flow rate ). If you go to the SAUER/DANFOSS site and read the spec's for the 1637 3-spool valve it should give you the factory settings.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #44
I guess my ignorance is showing more than normal. I do not understand how one can drain the lines/pumps/motors if inlets/outlets are all connected below the fluid level in the tank. Well, in my system I can understand because I have not fixed all the leaks so if the system leaks fluid out, it can leak air in. I do understand how it can overheat when one is recirculating the same fluid.
Ken
That doesn't tell me what the pump is rated at.
Those spool valve specs are what it can handle. The valves don't regulate pressure or flow. They just direct it.
Ken
Good point, Ken. Maybe excessive towing causes the wheel motors, which are acting as pumps, to pull a partial vacuum in the lines while forcing leak-by oil out the tram pump's return line.
The intake line is blocked by the non turning charge pump.
That isn't for the same pump series that is used in my PT-425. I don't know about the other models.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #48
Thanks for correcting me :D Maybe you can get that infomation from terry at PT.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #49
Bob999 said:
Yes that is the one. I had to cut (shorten) the dip stick but otherwise was able to use the cap as is.
Did the cap just screw on to the existing bottom?
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #50
I got my cap today and it works fine. Only about 1/4 inch clearance between the bottom of the seat and the top of the cap though. Did you adjust the seat any?
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #51
I did not adjust the seat. The only modification I made was to shorten the dip stick.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #52
I used the PT tonight and the new cap was torn off with bent tabs. I put the old one back on. I need to raise the back of the seat or maybe the whole seat.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #53
I have an 1845--I guess there are some differences in the dimensions and clearances.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #54
I did not know you had an 1845. I guess that explains the difference. I should have known better when I saw the 1/4 inch clearance with no weight on the seat.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #55
Perhaps this is a good time to remind folks to update their profiles?
Just a thought...
All the best,
Peter
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #56
Just a thought...
All the best,
Peter
Might also be a good time to remind people to look at other's profiles before making modications. That would have resolved my problem. Oh well. No significant hard done.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #57
Today I raised the seat. I drilled new holes in the seat support bracket arms that bolt to the PT tunnel. I was supposed to drill 2 holes, but I made two in the wrong direction first and then two closer to the arm ends. The new holes are about 1.5 inches down from the original holes (on the high end of the bracket in the picture. I also brazed washer to the holes, just like PT did. I had to make new stop bolt holes for the bolts that the support brackets hit when it is down (sitting position). The seat has a slight tilt towards the front, which I can adjust by enlarging the stop bolt holes (elongating would be better). I drove it around for about 30 minutes today and did not seem to notice. I actually have about 2 inches of clearance between the seat and the cap now. If I level it there will be less.
2006 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2006 CATERPILLAR...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2017 Case CX145D (A60462)
2017 Case CX145D...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
John Deere TX Gator (A60462)
John Deere TX...
