Tow/Bypass Valve Limitations PT-425 & Perhaps Others
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others
J_J said:
A better word or words would be AUX HYD . You can use it for whatever, a cylinder, hydraulic motor, The aux hydraulic has a small pump, somewhere around of 1.5 to 3 gpm. At least mine does, and this same pump also controls the steering, lift circuits, and aux hyd.
My PT manuals do not show the aux circuit at all, and the illustrated parts diagram does not break down the PTO/Lift/Steering pump at all, but treats it as a single part. I have no idea what the flow rate on mine is. The manuals can be very frustrating.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #42
Sedgewood had links to these files. In a way for me it give a clearer picture of how this pump works.
there are a few things I still don't get, but I want to formulate the questions clearly.
Here is the link to the PDF's as they are too big for TBN
ttp://www.sauer-danfoss.com/domdb/SASproducts.nsf/2dd81f77829d09d086256591004f57d7/5d44424d42f146f9862565d100577a08?OpenDocument
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #43
Isn't the AUX. HYD. /AUX. PTO circuit on the 422 & 425 operated by the lever by your right leg, and isn't that lever attached to the 3-spool SAUER/DANFOSS valve ?. So the flow rate would be what ever the spool valve is set at (pressure & flow rate ). If you go to the SAUER/DANFOSS site and read the spec's for the 1637 3-spool valve it should give you the factory settings.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #44
I guess my ignorance is showing more than normal. I do not understand how one can drain the lines/pumps/motors if inlets/outlets are all connected below the fluid level in the tank. Well, in my system I can understand because I have not fixed all the leaks so if the system leaks fluid out, it can leak air in. I do understand how it can overheat when one is recirculating the same fluid.
Ken
That doesn't tell me what the pump is rated at.
Those spool valve specs are what it can handle. The valves don't regulate pressure or flow. They just direct it.
Ken
Good point, Ken. Maybe excessive towing causes the wheel motors, which are acting as pumps, to pull a partial vacuum in the lines while forcing leak-by oil out the tram pump's return line.
The intake line is blocked by the non turning charge pump.
That isn't for the same pump series that is used in my PT-425. I don't know about the other models.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #48
Thanks for correcting me :D Maybe you can get that infomation from terry at PT.
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #49
Bob999 said:
Yes that is the one. I had to cut (shorten) the dip stick but otherwise was able to use the cap as is.
Did the cap just screw on to the existing bottom?
   / Tow/Bypass Valve Limitations PT-425 & Perhaps Others #50
I got my cap today and it works fine. Only about 1/4 inch clearance between the bottom of the seat and the top of the cap though. Did you adjust the seat any?
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
(2) Safemack 18.4-38 Tires w/Rims (A56469)
(2) Safemack...
John Deere Z540M (A56469)
John Deere Z540M...
