Torque specs
/ Torque specs #1
tarheel96
Tn
Yanmar
Does anyone know the torque specs for a ym1700 valve cover nuts that hold the valve cover down? I bought a shop manual and cant seem to find that one piece of info. I have all the other specs for the head bolts and everything else to put the motor back together. This is a link to hoye site showing a pic of what I am talking about. VALVE COVER NUT (EACH): Yanmar Tractor Parts
/ Torque specs #2
I would be very surprised if that was listed. Nothing critical there, just snug them down.
/ Torque specs #4
When I got my 2000 home,The same V-cover. I was going through it checking everything. I went to check my Valves and when I removed the cover there was no V-cover gasket and with no visible leaks. No way am I going to smell burnt oil and Diesel if it does start to leak. So I ran a bead of Silicone and let it start to dry and then snugged up the bolts. No Gasket, Been that way for 9-1/2yrs. without a drop...
/ Torque specs #5
The original valve cover gasket on YM240, and I assume YM1700, is rubber a little thicker than an innertube. It's intended to be reusable so don't gouge it getting the valve cover off!
I put a thin bead of silicone on the valve cover to force a tighter seal and stick the rubber to the valve cover. It never has leaked.
Similarly, I found a semi-permanent fiber gasket, like rope, embedded in a grove in the YM186's valve cover. Also don't gouge that one!
/ Torque specs
Thanks for all the help guys. I have all new gaskets from Hoye waiting to install as soon as I get time. Just wanted to double check things before I went to installing everything. I figured it was cheap insurance to ask! Thanks again
IRANCH Tire Changing Machine (A64194)
IRANCH Tire...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2002 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2002 Harmon Steel...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
