Top link
/ Top link
The stroke on that cylinder long 16 inch id be scare to bend that if you push it out to far
/ Top link #22
That cyl has a 1 1/4" rod. I don't think you well bend it, but if you did you would bend more then just the top link.
/ Top link #23
/ Top link #24
Do they make a 12v top link that would plug into the ready-made plugs?
/ Top link #25
coupman35 keep in mined the top hook up should be on the same center line as the lower link. This cyl would almost get you the 34" and also has the 1 1/4" rod.​
The problem with that one is the hole is not 3/4" and clearance at the base of the cylinder:
/ Top link
So after looking at a few top link this is the one am looking to get
/ Top link #27
When operating it, make sure the top link never is longer than your bottom lift arms. Otherwise, lifting will drive the tail of you implement into the ground.
Had this happen to my first bush hog when tractor was delivered. Had to change the bottom pins locations on the bush hog.
/ Top link #28
Sort of.. check this recent thread.
There may be times you want that. For example, for me one of the main purposes of getting a hydraulic top link is to be able to angle my box blade forward AND back. Forward lets me use the rippers alone. Level lets me use the front blade on the box without the rippers touching anything but high spots. Angled back lets me 'backdrag' (going forwards..) with the rear blade of the box.
But I understand that what you mean is that if the top link is longer than the bottom arms, it will lean the implement back further and further as you raise the 3pt and with a long implement like a bush hog that would be an issue. But with a power top link it's a problem you fix from the driver's seat in a matter of a few seconds. (y)
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
