Top link
/ Top link #1
coupman35
Northen Ontario
Now a L4060 had B2650
Need some info on hydraulic top link for my L 4060 .i GOT ONE WHIT THE TRACTOR BUT SEEM A BIT SHOT IT 21 INCH CLOSE AND 28 OPEN .Is that ok because yesterday i used my box blade but the link does not go out enough to give me the right angle .Look like i need a other 4 to 6 inch to make it work good .
/ Top link #2
I typically provide a 21"-31" working length for the cat 1 Grand Ls. That seems to work well for most people.
/ Top link #3
I installed this one last year. I wanted to get one from Brian @MtnViewRanch but needed it sooner. It's a little longer than he recommends but the extra length has come in handy with the land plane and landscape box.
It's also a Cat 2 and I wanted the rapid hook for the implement end. The only modification I had to make was to lightly grind the sleeve in the ball end where it attaches to the tractor. Being Cat 2 it was about 1/8 inch too wide to fit into the Kubota bracket.
I highly recommend it if you need something sooner than what Brian offers.
/ Top link
I got a hydraulic top link whit my new tractor 1 month ago but like i said it only open to 28 inch . Am trying to find out if any one got one from kubota whit a l 4060 and if it the same as mind only open to 28 inch also.
/ Top link #5
Did you ever check to see what the full extended length of the original manual top link measured ?
/ Top link
Yes i saw that but am going to check whit my dealer maybe they give me a smaller top link.
Dont what to bye a other one this one new first time i try it yesterday
/ Top link
I like that extender and i can weld that easy to make thanks for info
/ Top link
How much longer did that extender give you . The dealer said the other top link they can get it 24 to 32 inch that dont sound ok
/ Top link #13
The hydraulic top link I got from Brian( Fit Rite Hydraulics ) extends a couple inches more than the OEM that came with my tractor. It's been a real life saver. It allows me to "fine tune" implements to their max.
/ Top link #14
You can make it as long as it needs to be.
/ Top link
Yep your right am going to do it today .I guess if i do it to get 3 to 4 in extra that be ok
/ Top link #16
20 7/8" - 31 7/8" with free shipping. $224.99
The one the dealer is offering will limit adjustment on the short end, as will an extender.
/ Top link
Yep but 224.99 that in USA fun and free shipping in the USA .
/ Top link #18
Yes, sorry you are correct. I'm ordering from these guys as soon as I get my tractor next week and confirm the short and long adjustment length on my top link. I like that they include the check valve so the cylinder doesn't creep down.
/ Top link
IT done I try it out and it working good now
/ Top link #20
