Top link
   / Top link #1
coupman35
Northen Ontario
Now a L4060 had B2650
Need some info on hydraulic top link for my L 4060 .i GOT ONE WHIT THE TRACTOR BUT SEEM A BIT SHOT IT 21 INCH CLOSE AND 28 OPEN .Is that ok because yesterday i used my box blade but the link does not go out enough to give me the right angle .Look like i need a other 4 to 6 inch to make it work good .
   / Top link #2
I typically provide a 21"-31" working length for the cat 1 Grand Ls. That seems to work well for most people.
   / Top link #3
I installed this one last year. I wanted to get one from Brian @MtnViewRanch but needed it sooner. It's a little longer than he recommends but the extra length has come in handy with the land plane and landscape box.
It's also a Cat 2 and I wanted the rapid hook for the implement end. The only modification I had to make was to lightly grind the sleeve in the ball end where it attaches to the tractor. Being Cat 2 it was about 1/8 inch too wide to fit into the Kubota bracket.
I highly recommend it if you need something sooner than what Brian offers.
   / Top link
I got a hydraulic top link whit my new tractor 1 month ago but like i said it only open to 28 inch . Am trying to find out if any one got one from kubota whit a l 4060 and if it the same as mind only open to 28 inch also.
   / Top link #5
Did you ever check to see what the full extended length of the original manual top link measured ?
   / Top link
Yes it 34 inch center pin to center pin
   / Top link
Yes i saw that but am going to check whit my dealer maybe they give me a smaller top link.
Dont what to bye a other one this one new first time i try it yesterday
   / Top link #9
If the dealer does not have a longer one a top link extender would work:
And if you do not weld: Easy top link extension
   / Top link
I like that extender and i can weld that easy to make thanks for info
Land Honor Quick Attach Rock Bucket (A50514)
Land Honor Quick...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52128)
NEW 2022 Load...
CRESCENT SUPPLY 20 CONTAINMENT TRAILER (A50854)
CRESCENT SUPPLY 20...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
