Toplink top link question
/ top link question #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I bought an aerator and after I put it together, I noticed that my top link won't fit. The manufacturer says that:
There may be alot of this type out there, but the standard would be closer to 1 3/4 inches wide without the bushing extending out past the ball joint.
I looked on the TSC web site and all the top links look like they have the bushings on the ball joint. Are there bushing-less top links readily available?
/ top link question #2
They need to improve that design. I've never seen a top link narrow enough to fit in that small space. What are the two pieces of angle held on by? Welded?
/ top link question
It's bolted together. In an email today, I told them that they ought to review the design cause it's really dumb. I think I'll just jigger it to see if I can use my usual top link.
/ top link question #4
You can always grind the ears off'n yer toplink... they are cheap enough..
soundguy
/ top link question #5
Add washers to this bolt till it is wide enough.
/ top link question #7
Yes.. both in length and pin size..
soundguy
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A68183)
2017 Chevrolet...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
PORTAPOTTY TRAILER (A68842)
PORTAPOTTY TRAILER...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
