Toplink top link question
/ top link question #1
GaryS
Gold Member
franklin park, pa
Kubota L3901 & LA525
I bought an aerator and after I put it together, I noticed that my top link won't fit. The manufacturer says that:
There may be alot of this type out there, but the standard would be closer to 1 3/4 inches wide without the bushing extending out past the ball joint.
I looked on the TSC web site and all the top links look like they have the bushings on the ball joint. Are there bushing-less top links readily available?
/ top link question #2
They need to improve that design. I've never seen a top link narrow enough to fit in that small space. What are the two pieces of angle held on by? Welded?
/ top link question
It's bolted together. In an email today, I told them that they ought to review the design cause it's really dumb. I think I'll just jigger it to see if I can use my usual top link.
/ top link question #4
You can always grind the ears off'n yer toplink... they are cheap enough..
soundguy
/ top link question #5
Add washers to this bolt till it is wide enough.
/ top link question #7
Yes.. both in length and pin size..
soundguy
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
Hydro-Ax 721E Articulating Mulching Forestry Tractor/ Land Clearing (A66734)
Hydro-Ax 721E...
213130 (A64276)
213130 (A64276)
