top link lifting force lbs.
/ top link lifting force lbs. #21
Fixed it, should have double checked . I thought it looked odd, but calculators don't lie do they.
pull 5085 lbs
rod size 1 & 1.1875 in
:thumbsup::thumbsup::thumbsup:
/ top link lifting force lbs. #22
What is the maximum stroke length the disc was designed to use? If the cylinder has to much stroke, will it bend something on the disc? I would go with 2.5" diameter. The tie rod cylinders have been around forever, and are decent quality
I was going to say the same thing. :thumbsup:
Also from the looks of your pic you have a tie rod style on it now, correct?
Yes tie rod piston, I bought the disk last year the main channel down the middle was cracked, had to stitch some beads so I could disk, in September I took apart the disk to re furbish, old worn disks were 15 to 17 inches, tires were shot, new. : 20" disks,tires,bolts, 3" c channel that wheel carrier bolts to, new main frame tube 4 x 4 x 3/8, paint, hoses.
The old disks with 8" stroke piston would make contact with the ground, with new 20" disks, I am looking for 3" or so more height,
I have 6" before tires make contact with front gangs.
I will re assemble the disk and and measure for piston
Sorry for the confusion, I was just looking to use a piston I had, but as someone said for 100 bucks buy the right one. Thanks again for the input. Dennis
/ top link lifting force lbs. #24
It would be cheating to ask the JD dealer exactly what cylinder that disc was designed to use.
/ top link lifting force lbs. #25
Sounds like you have your bases covered.
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
