top dead center
/ top dead center #1
tmar04
YM 276
I am planning to replace valve stem seals on my YM2500 (3T80) with head on. What is easy way to tell when piston is at, or near, TDC, to preclude valve from dropping into cylinder? can't stick straw into injector hole because of the 'precombustion chamber'. got to be an easy way. thanks to all.
/ top dead center #2
The best way I found was to rotate engine by hand. When compression is felt (rotating will get hard), Push down one of rockers, for each cylinder, one at a time. 2 of the 3 cylinders will not affect ease of rotation. 1 cylinder will cause rotation to get easier and you may hear air excaping from cylinder either thru exhaust or intake, it depends on which rocker you push on. Then you know that that cylinder's piston is on its way and close to TDC.
On my 3T80 there are marks for 1,2, and 3 TDC, if yours does to, that will help.
Be advised that this proceedure is how you adjust lifters too! And is how I determined I had poor compression in 2 cylinders, prior to my rebuild. While rotating engine it never got difficult to rotate by hand, until #3 cylinder came up to TDC. Implying that 2 of the 3 cylinders had poor compression.
/ top dead center #3
Another easy way is with the valve cover removed, rotate the engine until you see the 2 valves rocking..(exhaust valve will be closing and the intake will start to open, technical term is valve overlap). Then turn the engine another 360 degrees and you are close enough. When the exhaust valve is closing at overlap, the piston is pretty close to TDC, the intake valve starts to open as the piston moves down to suck in more air.
Work your way to the other 2.
Good Luck!
/ top dead center #4
Hey Rock, what lifters are you talking about. All diesels I worked on had basically a solid lifter riding on the camshaft. No adjustments.
If you are talking about adjusting the valves...well then nevermind. :D :D
Rob
/ top dead center #6
I use a bicycle spoke through the combustion chamber cone...a gentle probe will indicate the piston travel height.
Once you've pulled the valve keepers it may be necessary to keep compressed air in the cylinder to reassemble the seals, springs and keepers...not sure as I haven't done it that way.
Mark
/ top dead center #7
Air usually not needed on a diesel. Flat top piston and a flat head. This is my Kubota which probably is the same as most small 2-3-4 cylinder diesels.
Rob
/ top dead center
Rock2610D, thanks for tip on TDC on 3T80 eng. Mine has the same three marks on pulley, 1-2-3. If I line up the #1 mark with the pointer, does this mean #1 piston is at TDC? Sure would simplify matters. thanks.
/ top dead center #9
Its a 4 stroke engine. Up once for compression, down once for power stroke, up once for exhaust stroke, and down once for intake stroke.
I believe that when the cylinder # is aligned with the pointer its either in the TDC of compression stroke or exhaust stroke. Not 100% sure though so if I were you I would double check, because its a 3 cylinder and I could be wrong, as firing order is 120 degrees apart.
/ top dead center
just had a thought. when I get piston to TDC, and strike the top of valve spring,keeper, won't this drive the valve down, causing it to hit the top of piston? I don't like this idea. I need to be able to secure valve someway to keep it from going down into the cylinder.
/ top dead center #12
Not sure why you would "strike" anything. Use a valve spring compressor, compress springs and remove keepers, then release compressor and remove spring. RIGHT??
/ top dead center #13
Hey Rock,
tmar04 is talking about replacing valve stem seals without removing the head.
It will be anything but easy/tricky to keep the valve stem height in place while collapsing the sping, installing the keepers.
I wouldn't hesitate to pull the head, dress the valves and seats (even hand lapping them) and re-assemble the head with a new head gasket. Reset the valve clearance and your good to go.....
Mark
/ top dead center
Mark, I think you are right. I had the head off last week, but did not realize smoke was so bad. no big job to remove. thx
/ top dead center #15
It won't heart anything, just don't hit the valve stem. By hitting the spring the stem doesn't move much anyway. That's why this way of removing the keepers/springs works head on or head off. You don't need anything to back up the valve from the bottom. Even if you use a compressor, the valve may still hit the piston to free the spring retainer and keepers. Remember they've been stuck together for some time.
If you are really worried, just lightly hit the springs to loosen the retainer from the keepers, then just press the spring down by hand or with a wrench, have a helper use a magnet to grab the keepers. It'll still press against the piston...it has to...gravity and all. :D
/ top dead center #16
It really isn't if you done it before. Besides a head gasket is around $50 or more for my L.
Good Luck,
Rob
/ top dead center
Rob, Thanks for tip. I'll try it and let you know how i do. Terry
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2017 Ford F-450 Liftmoore 5000W 5,000lb. Crane Service Truck (A61573)
2017 Ford F-450...
1994 John Deere 8300 (A64126)
1994 John Deere...
LS MT225E (A64126)
LS MT225E (A64126)
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
