toothbar in action
/ toothbar in action #23
I ordered one from marham welding today, very nice to deal with, but they said they are out of teeth until after the first of the year, so it might be a little bit before they send it off. The price was right...
/ toothbar in action #24
</font><font color="blue" class="small">( I ordered one from marham welding today, very nice to deal with, but they said they are out of teeth until after the first of the year, so it might be a little bit before they send it off. The price was right... )</font>
I ordered mine several weeks ago and they shipped it last Wednesday...supposed to get it Thursday. Can't wait...those nice pictures makes me want to go kill some dirt....Yikes... Looks like nice weather up there too.
/ toothbar in action #25
Same here. UPS will deliver the Markham toothbar for my B7510HST/LA302 FEL Thursday. Looks like we ordered just as the supply of teeth was running out.
Plan to use the toothbar/FEL next week to excavate a 6"D x 48"W x 70'L trench for a paver block walkway
/ toothbar in action #26
Uh, oh. Mine was supposed to ship on on Friday the 9th and then I would get a call with the tracking #. No call, and now they're out of materials? I was hoping for a delivery before this weekend but if I need to wait until next year then that's OK I suppose. /forums/images/graemlins/confused.gif
/ toothbar in action #27
</font><font color="blue" class="small">( Looks like we ordered just as the supply of teeth was running out.)</font>
Yeah, just lucky I guess...
Actually, mine was supposed to ship the week before last but they called me saying they had a problem in the machine shop so it would ship the following week and I'd get it tomorrow. Lucky thing I didn't wait any longer to order. Turned out OK though, since I didn't go up to the property last week anyway. I'll have plenty for it to do when I get up there. Bringing my old arcwelder up up to weld on those side brackets.
Also bought a 1/2"Ø capacity D-Handle drill motor to drill my bucket. Harbor Freight had one on sale for $29.99...can you believe that? Also have a set of Silver & Demming drills with 1/2"Ø shanks. Next week I'll make a post to show all the goodies I've bought for the tractor...set me back about 3 Christmas's worth.
/ toothbar in action #28
I drilled the bucket of my CK20 with an 18v battery powered drill and a titanium coated multipurpose bit. Duck soup. Took about 30 seconds. Just remember to use a bit of oil as a lubricant for the bit.
/ toothbar in action #29
I drilled mine with a 12v drill and a Uni-Bit step drill bit. If you've never used one of these you don't know what you are missing. They are, by far, the best drill bits for sheet metal. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif Looking for something to ask Santa for? I highly recommend having a set in your toolbox. They cut perfectly round holes in sheet metal and if you hit the hole a just touch more with the next step it will remove the burr as well. Then go at the hole from the other side and do the same and you're done.
/ toothbar in action #30
Good tip on the uni-bit. I've never used one in my machining trade so I always used straight shanked drills...requiring machinery to have the chuck capacity for them. Never thought of them...Thanks.
/ toothbar in action #31
I have become a fan of bimetal hole saws, at the advice of Madref. Great for thin stuff and awesome for plate as well. So far I've cut a 1" hole thru 1/2" plate ... like butter, on the drill press. Best thing is the holesaws don't grab the steel and throw it across the shop like twist drills can when they gouge/grab a burr.
Cheers!
/ toothbar in action #32
A little off topic... but how thick a piece of soft steel will the uni-bit handle? I realize a bucket side isn't too awfully thick, but would you consider it "sheet metal"? I have thought about getting a set of uni-bits, but didn't know if they could handle 1/8, 3/16, 1/4" steel or not. What's the answer?
/ toothbar in action #33
I used a Unibit. It was the only way I could drill the holes... my cheapo twist bits would catch then break in half. Unibits are really the greatest thing.
/ toothbar in action #34
Sorry to spread the bad news about the teeth, but that is what she told me on the phone the other day, fortunately I guess I don't have to have it right now... But I do like to get my toys or I mean tools right now when I want them....
/ toothbar in action #35
It's all sheet metal up to 1/4" after that it's considered plate.
I doubt that most bucket walls are much thicker than 1/8". As long as you use some lube to aid and cool the tool you shouldn't have any trouble drilling 1/4" or even thicker. Different bits have different step heights as well. I have one 1/2" diameter bit that I think the steps are about 3/8" high. Just use a taller step with the thicker material if you can. These bits are really designed for thinner sheet metal. Their single flute design allows them to drill smoothly without catching and twisting your arm off the way a regular jobbers drill would. Two flute jobbers drills are better suited to the thicker material, but if you could imagine trying to drill a 3/4" hole through a piece of 1/4" with a pistol drill you might find that the unibits excel there as well. I know I wouldn't try that with a regular bit.
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
INTERNATIONAL 986 TRACTOR (A64278)
INTERNATIONAL 986...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
1995 CATERPILLAR 140G MOTOR GRADER (A65053)
1995 CATERPILLAR...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
