Tooth bar question?
/ Tooth bar question? #1
gwstang
Platinum Member
Lake Martin Alabama
1952 Ford 8N / Kubota L2501
I've looked/read on here about the tooth bar add on for a front end loader on the tractor. How does the bar help to push up small saplings (1" or so) or heavy brush? I guess I mean how does the mechanism of the toothy bar makes it work better? Is the loader edge of the bucket too smooth, by itself, to "grasp" the saplings/brush and just sort of "mashes it down without actually pulling it out? I do get frustrated with just having the loader do this sort of thing. Enlighten me tractor gurus. :confused2:
/ Tooth bar question? #2
I usually use my backhoe for such jobs, but with careful tooth placement the tooth bar does work,
"tooth placement"...how do you mean? More in or out on the FEL edge?
/ Tooth bar question? #4
I bought one of these a few years ago.....I rarely take it off my bucket. I have cleared acres of blackberry and small alders. I had one custom made for my small yanmar 186d........works great.....check them out.
BXpanded Piranha Tooth Bar
/ Tooth bar question? #5
For brush, the tooth bar can rip up the roots usually and tear everything out that way but for saplings, seems to me there's nothing for the teeth to latch on to except for part of the root maybe. Pulling up saplings is not the toothbar's greatest strength, IMO. That would be for digging into dirt and pulling out rocks, etc.
Thanks, I will check that out! :thumbsup: I like the way that bolts on.
Thanks, there are plenty of rocks around here for sure...Bush Hog does a pretty good job of making "smaller" rocks out of the big ones. :smiley_aafz:
/ Tooth bar question? #8
/ Tooth bar question? #9
I got the BXpandable tooth bar for my JD and it does do a better job or ripping out shrubbery than a flat edge on a loader and up to one inch saplings it usually can handle it pretty well depending on the type of tree. It does also help the loader quite a bit when scraping and you hit a hardpan of clay. For the price of the add on implement they are worth the money.
/ Tooth bar question? #10
I stab a tooth under the roots to snag it, then pop it out by driving forward. With just the flat edge of a bucket, you can't slide under the trunk without digging up a really big, wide divot. An alternative is a tool that grabs the trunk (eg like a claw hammer) as you drive forward, pushing it over and then out of the ground.
/ Tooth bar question? #11
The tooth bar will help a lot. The teeth can rake through the top layer of soil where the roots are and rip them and you don't get piles of dirt. You can't do that with a blade edge. If you push a tree over and then get under the root ball to free it the big teeth on a tooth bar will really help you grab on and rip it up. When you are done the teeth make a nice brush rake too.
I put a tooth bar on a year ago and can not believe the difference it makes in everything.
/ Tooth bar question? #13
I have one on my 2370-1 - Its like a hot knife in butter. I can rip up some smaller trees up to about 3 inches or so. Digging? Like a VietKong tunnel rat! Take the place where the teeth come to a V and notch that against the tree, up and back on the FEL...tree comes right out. If you dig them up some and its wet you can pull out pine thats bigger. Most awesome add on, I use the underarmour as well.....Makes a small machine a banshee in the woods. Im clearing my lot a little each weekend with it.
Thanks for the info. I just bookmarked that for reference! :thumbsup:
Thanks guys. I think I'll hit swmbo up for one of these (Bday)
/ Tooth bar question? #16
I meant tooth placement on the tree. You have to get a tooth under the root ball.
/ Tooth bar question? #18
I have to say the toothbar is one of the best things i bought for my tractor. many more benefits than problems.
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
Barrel (A64557)
Barrel (A64557)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
