Tools & equipment that are fantastic.
   / Tools & equipment that are fantastic. #411
I went through 2 gallons last week in the saws and use about a gallon every time I fire up the weed whacker. Lots of obstacles to trim around ( not mine) and more than mile of shore line around the ponds. That does not include the areas of the dam I can't cut with mowers,
Not here and I roast the ditches every spring anyway.
   / Tools & equipment that are fantastic. #412
Since we do trail work, i so guess I'd have to say a 6x6 is. Or did I already post that?
   / Tools & equipment that are fantastic. #413
I'll have to say I'm favorably impressed with my Harbor Freight battery chainsaw,
after our heavy wet snow brought so many limbs and trees down in the driveway that little saw did a good job dropping them. Much easier then trying to get my older gas power saw started after it has been sitting untouched for over a year.
   / Tools & equipment that are fantastic. #414
I love these staplers. As you bear down on the trigger, you are also pushing down on the front of the stapler where the staple comes out therefore squeezing the material together.
They take Arrow T50 staples too.
   / Tools & equipment that are fantastic. #415
I have one of these too, use it all the time, but it does misfire a lot.
   / Tools & equipment that are fantastic. #416
Oh, I should add that the 72" plow we got for a 6x6 was one heck of a tool to get snow pushed around. Was one of the best accessories we got for the 6x6. Retired the snow blower (still have it)
   / Tools & equipment that are fantastic. #417
My wife has one of those, I find it hard to use with my large hands. Agree with kenmbz about misfires.
   / Tools & equipment that are fantastic. #418
Power stapler - Air or Electric (even battery)
Find I spend more dragging it out than using a manual but........like a FEL it beats a wheelbarrow
   / Tools & equipment that are fantastic. #419
For a few years I'd put a plow on my Outlander for those storms not big enough to be worth using the tractor to plow (and was quicker for those smaller snowfalls too). I found it rather balky shifting between fwd & reverse, sometimes having to rock the quad back & forth to get it to go into gear. Eventually decided it wasn't worth stressing the machine over and stopped using it for that. Only had a 42 (?)" plow on mine.
Do you have this problem?
   / Tools & equipment that are fantastic. #420
No. it generally shifts without greif.
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2242 (A58376)
2242 (A58376)
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
