Toolcat Series?
/ Toolcat Series? #11
And a snip from SSdoxie​.
attachment.php
/ Toolcat Series? #12
Bobcat's historical specs are being updated and are not available on their site currently. :(
I know that the 5600 used be able to be factory (or dealer) fitted with a PTO. Does anyone know what the last model that was capable of that attachment was? or will it still work on the current ones?
Thanks
/ Toolcat Series? #13
Thanks
C series was the last one. D series did not because thats when the 5610 was introduced.
/ Toolcat Series? #14
Thanks! The C was the first one with independent suspension on all 4 wheels right?
Any issues or quirks a guy should be aware of when looking for used ones?
Thanks
/ Toolcat Series? #15
Thanks
What will you be using a 5600 for? Do you have to have the cargo box?
My 5610 has the PTO, have only used it with a post hole digger. :thumbsup:
This is the only picture that shows the PTO up close.
/ Toolcat Series? #16
No. C series still has the solid one piece axle. See thread Toolcat, weak drive motors.
/ Toolcat Series? #17
What will you be using a 5600 for? Do you have to have the cargo box? My 5610 has the PTO, have only used it with a post hole digger. :thumbsup: <img src="http://www.tractorbynet.com/forums/files/toolcat/444066-toolcat-series-pc190005-jpg"/> This is the only picture that shows the PTO up close. <img src="http://www.tractorbynet.com/forums/files/toolcat/444067-toolcat-series-p5240040-jpg"/>
Probably not a ton of things for the pto but we do have a post hole digger and a 5 foot bush hog style mower though I likely would look for a front mounted flail mower to purchase with the toolcat.
I just like the flexibility.
As far as the box, countless things. We have a 50 acre property to maintain with horses. We'll use the box and use it a lot, though if we upgraded to a heavier duty utv maybe that would be minimized. But nice to have the convenience for multiple things.
/ Toolcat Series? #18
Have you thought about a front mounted motorized 3 point adaptor?
/ Toolcat Series? #19
I hadn't that would certainly be a consideration. Do those yield the same HP rating?
/ Toolcat Series? #20
What is the top speed of a tool cat? How smooth do they ride running fast across a field compared to a ATV?
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
Case TV620B (A60462)
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
Iranch IRGC40 (A60463)
