Mowing too warm
/ too warm #1
upsetray
Salem , NY
(2 Units) Bolens Iseki H-1502
I have owned my H-1502 since new and has been stored inside . When mowing ,if ambient temperature is 90degrees ,my light will come on ,usually I have to return to shop to blow out radiator and tranny cooler ,. That helps but wondered if everyone else experiences the same over heating in warm weather. How do you deal with it ?
/ too warm #2
How would I deal with it - - - hmmmmm....... I'd blow out the radiator and tranny cooler BEFORE starting the work day. Might help to drain and flush the cooling system with a system cleaning solution also.
/ too warm #3
Does it have fan belt??? check see if loose or needs replacement.
/ too warm #4
You might try testing the light switch and see what temp it turns the light on. Maybe you don't have a serious heating problem but a temp switch problem.
2016 John Deere 544K Articulated Wheel Loader (A64553)
2016 John Deere...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2020 CATERPILLAR 299D3 SKID STEER (A65053)
2020 CATERPILLAR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
CASE IH RB464 ROUND HAY BALER (A64278)
CASE IH RB464...
