too short pto shaft?
/ too short pto shaft? #1
gav64
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
my chipper pto shaft is too short to work with my speeco quick hitch. Can you safely lenghten the shaft, or can you use a spline extension like you would use for a pto pump or should i just go out and by and other shaft. thanks glenn
/ too short pto shaft? #2
I've seen folks legnthen PTO shafts. You CAN use an extention/adapter.
BUT. If it were me, I'd spring for a PTO shaft that's the correct legnth. They're not that expensive.
I'm a saftey fanatic. JMHO
/ too short pto shaft? #3
On most PTO shafts the tubes are replaceable by driving out the pin holding the tube to the yoke. Then you can replace with a new tube, reinstall the roll pin and then cut to length needed.
Lewis
/ too short pto shaft? #4
I measured to figure out how much longer I needed my tiller PTO shaft after installing a quick hitch. Took it to a drive line specialty place (for truck shafts).
They found me a drop off piece and cut it to length for me for $20. Buying a 4 ft stick at TSC would have been $50--if they had the size I needed, which they didn't.
If you take the whole thing, they can do it in a fraction of the time you or I can.
Ron
/ too short pto shaft? #5
That is cheaper than my idea of using a 1 3/8 to 1 1/16 adapter then a 1 1/16 to 1 3/8 adapter on that. The whole arrangement would run around $40, but the part are easier to find than an old shaft. /forums/images/graemlins/wink.gif
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2022 EZ-GO ELITE...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
