too much fertilizer
/ too much fertilizer #1
mulitweed
john deere
so im a hobby farmer , neighbors terra gator blew up last year full of fertilizer, we emptied it out i put some in some old chemical totes , the rest i dumped on my plot , i covered it until fall when i spread it , nitrogen, where i had the pile the soil has turned to muck , maybe this fall deep rip that area ? your thoughts , thanks
/ too much fertilizer #2
Dig up the dirt, mix with some more dirt and spread it like you would spread fertilizer.
Or if you compost leaves and stuff, add it to the pile - it will speed up the process and make good compost.
thanks
ive been digging it trying to air it out , its like quicksand
/ too much fertilizer #5
Nitrogen is very hygroscopic, meaning it will easily draw moisture from the air. If you've had much rain or high humidity it will just keep drawing moisture until it gets diluted.
As mentioned above, mixing it with some "browns" leaves, straw, etc., will help in breaking those items down into a compost mixture.
thanks ill get some grass clippings anything else i can get and mix them in , wont make this mistake again
/ too much fertilizer #7
Actually, grass clippings are around 4% nitrogen, so you could be adding to the problem.
ok thanks, what should i mix in there ?
manure ?
/ too much fertilizer #10
No manure has more nitrogen too - anything like leaves, straw, composted wood chips, dirt, etc. If you dont have any go buy a bale or two of mulch hay (they sell at farm stores etc) and mix it in.
/ too much fertilizer #11
Straw?
I'm thinking nitrogen is acidic, straw more alkaline. Just my guess though...
Maybe some lime?
Here I've taken soil samples to our local Southern States who sends to Virginia Tech.
A report comes back showing what it is and what to add depending on what you want to grow.
just had some stumps ground at my moms , that will work thanks
Straw?
Maybe some lime?
soil is sandy on a gravel ridge , hopefully can have my renter dip rip this fall that should help , i have access to lime if that would help?
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2015 Ford Transit 150 Cargo Van (A59230)
2015 Ford Transit...
2011 Kubota KX080-3 Midi Excavator (A59228)
2011 Kubota...
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
