TODAYS SEAT TIME
/ TODAYS SEAT TIME #13,641
They're not always that bad. This job was easy:
Just an overgrown lot in town. Just grass, thick at times, but nowhere was it taller than my hood.
Another "easy" one. Just grass, very few objects hidden in the grass, few large rocks but I could see the ground through most of this and could spot them.
This one was just thick grass, with a few rocks. Hard to see them with how thick the grass was. Easy job though, just a utility right of way job. It was just a large area.
/ TODAYS SEAT TIME #13,642
Here's a pallet I found:
It used to be on that stack of pallets to the right. Wind or thoughtful passer-by tossed it onto the ground. Found that without "magic", too. Made a bunch of noise when I found it though. Bucket went right over that one too.
/ TODAYS SEAT TIME #13,644
2 hrs yesterday on The MX5200 with the chain mower on back. Neighbors field was 7 ft tall in places, very thick mustard stands. We finally got a little rain and the cooler weather, I wanted to cut without fire hazard as it was all dried out.
No pics of the work but here is the chain mower. Slashed the heck out of everything.
/ TODAYS SEAT TIME #13,645
Just finished building a small one for my excavator. Still needs painting.
The plan is to use it on some tall embankments that I can't reach with the tractor. I built a flail cutter for the excavator a couple years ago. Worked ok but it's just too heavy.
/ TODAYS SEAT TIME #13,646
That is a handsome beast! Tell us about the hydraulic motor, flow rate and rpms?
/ TODAYS SEAT TIME #13,647
I happen to have two Parker F11 5cc piston motors. One is being used as pump for the aux circuit.
The other one is what's on the cutter.
At 2500 engine RPM, I get about 2000 RPM on the cutter. It worked ok with the flail. I think it'll be fine in this cutter as well.
Not a tremendous amount of power but the whole thing is powered by a small 17hp Kubota D640 engine. Eventually I would like to upgrade to a 25 HP air cooled diesel engine. A Lombardini, Deutz or similar.
/ TODAYS SEAT TIME #13,648
I ran my engine speed up to 2500-2600 while using the chain mower yesterday and today. That is very close to PTO 540 rpm marker and the mower cut better than it had previously on lower rpms. #7 hardened chain holding up well so far, may get a second season out of them before replacement.
/ TODAYS SEAT TIME #13,649
These cutters with chains use a 1:1.92 ratio gearboxes. If I recall correctly from other threads, yours has 1:1 or close to anyway. You'd be even more happier with the results with the 1:1.92 gearbox.
Once you replace the chains, go with grade 80 chains, although I wouldn't trust welding them. That is the correct chain to run on these type of cutters.
The ones on my cutter for the tractor have been there for around 300 hours of brush cutting and since I tend to run the cutter just about 1 to 1.5" off the ground, it tends to hit dirt a lot and cause premature wear, other wise it would last even longer.
The cutter for the tractor uses 1/2" chain and the cutter for the excavator uses 3/8". I do have two spare sets for the tractor.
/ TODAYS SEAT TIME #13,650
After 6 weeks of drought, we finally got some rain, so I broke out the old Ferguson Yardmaker to do some overseeding yesterday. It was a little wet, but I can't afford to be too picky. Was just glad to have enough moisture to get the tines to penetrate.
Took me about a half hour to scrape all the mud/grass build up off the drum.
NOTE: The author in NO WAY endorses operating tractors with ROPS in lowered position, especially when using heavy, ground-engaging attachments on the three-point hitch.
/ TODAYS SEAT TIME #13,651
Coffee through the nose - thanks to the author!
/ TODAYS SEAT TIME #13,652
Caught in the wild, a rare photo dated 5/17/08 of Runner operating his tractor with the ROPS deployed and seat belt on.
/ TODAYS SEAT TIME #13,653
Pulled up this seasons thatch (which wasn't all that bad this year), mulched and aerated today.
Its difficult to see the holes and cores in the longer grass when taking photos
The morning dew is hanging out longer now, so I think I'm gong to let the property sit for a few weeks
I may only have 1 or possibly 2 more cuts left before the white stuff comes.
Sky Plant Natural landscape Tree Grass
Green Plant Sky Natural landscape People in nature
Sky Plant Green Natural landscape Tree
Cloud Sky Plant Tree Natural landscape
Plant Natural landscape Grass People in nature Agriculture
/ TODAYS SEAT TIME #13,655
Good Evening,
Actually a few days ago, got the second mowing in for our field ! About 5 hours total, I was worn out by the end of the day ! 😉
/ TODAYS SEAT TIME #13,657
Dug a ditch today little Kioti did the digging and the Branson moved some of the spoils piles. Propane tank should be delivered tomorrow, build up a couple of gravel pads for the tank to sit on and 50 to 60 foot of ditch for the line to go in. Was wishing for a narrower bucket, but when I got down in to dress it up a bit and get any loose rocks out it was narrow enough.
/ TODAYS SEAT TIME #13,658
I mowed a few more acres of dry grass with the rotary cutter, wishing that I had finished mowing everything while it was still green and not so dusty. I’ll do a few more acres next week, then mow the garden down after the first frost. Then it will be time to retire the rotary cutter for winter, with 10 acres mowed around the house and outbuildings.
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
