TODAYS SEAT TIME
   / TODAYS SEAT TIME #13,381
Cleaned up leaves that had been pulled out of the drainage.
   / TODAYS SEAT TIME #13,382
Mowed a pasture for the neighbor lady. The mower found an old T post, a kitchen knife, and a 1/2" PVC riser :rolleyes:.
Finally found the right water shut off and fixed the pipe before I left.
   / TODAYS SEAT TIME #13,383
How did you notice the kitchen knife? Nice of you to fix the pipe for her.
Man, the things I've found while mowing, lol.
   / TODAYS SEAT TIME #13,384
My brand new Z-turn, first time out and I found the missing coulter off my two bottom plow. :(
That was a $300.oo repair and free haulage back to the seller. Bent a spindle.
   / TODAYS SEAT TIME #13,388
After pushing over a weeping willow and digging it out, I noticed a big trail of hydraulic fluid from the old 550 Ford TLB. Checked the rear axle and was low almost 3 gallons. Filled back up and parked it putting cardboard underneath. O OH ripped brake rod seal.
Luckily I had another one ( changed the other side over a year back) so drained about 4 gallons out and replaced the rubber bellows.
Strained the oil back in and needed Another 3 gallons... That should take care of the rear axle.
Did some leveling of the field road and The old beasts drive is quieter, with a full sump. :)
ps. Next up backwoods Mod of adding a 12Volt pump powered hydraulic
dual acting cylinder for the at the moment fixed thumb backhoe...
   / TODAYS SEAT TIME #13,389
no seat time lately, just staring at taxes and spreadsheets
   / TODAYS SEAT TIME #13,391
The broken stainless blade was shining in the sun so I stopped and picked it up...was glad it didn't poke into my tire !
I recall a time when I mowed over a pile of bailing twine... it took me forever to cut it all out of the flail mower o_O
   / TODAYS SEAT TIME #13,392
Cutting it out is torture, but a propane torch makes the job quick and easy... Been there and done that!
SR
   / TODAYS SEAT TIME #13,393
I envisioned the mower picking the knife up and flinging it. Either way, it would have been ugly.
I once ran over a length of chicken wire with my pickup, wrapping it up in the drive shaft. That was bad enough to dig out.
   / TODAYS SEAT TIME #13,394
Did the exact same thing scootr . . . happened about fifteen years ago and your right it takes like forever to cut it out.
   / TODAYS SEAT TIME #13,395
I ran out of expletives ~ mostly directed at the previous owner who left the trap in the overgrown weeds. :p :LOL:
   / TODAYS SEAT TIME #13,396
Heh Heh that is in the same fun category as winding it up on a large 3 point tiller while you are mixing in Horse manure while making some planting soil.
Time to run the pressure washer for 1/2 an hour before even thinking about removing it.
Unfamiliar field mowing I managed to find 4x4s which the mower broke into multiple pieces, large cinder blocks and half buried car tires. I think the cinder blocks were the worst, made the biggest racket and added lots of raised dents in the mower housing.
   / TODAYS SEAT TIME #13,398
Trying to consolidate some implements.
Moved the old disc over with the inverted snow blower and spike harrow.
Then decided to weld up a hole that was punched into the bucket.
   / TODAYS SEAT TIME #13,399
I use a 5 lb hammer to fix a bent spindle. Hidden
rocks sticking up in high grass will surely do a number
on a spindle
willy
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2444 (A60432)
2444 (A60432)
