TODAYS SEAT TIME
   / TODAYS SEAT TIME #13,301
Mesquite burns hot, bring some meats to that fire(y)
   / TODAYS SEAT TIME #13,302
Scootr that brush pile is so big full of cactus, cedar, misquite, old
boards pine and cedar too far gone to use. When we get some
snow here hope to burn it off. With; the heat from the cedar, pine
and misquite don't think you would be able to close enough to
roast a hot dog unless you had maybe a 10 ft pole????
willy
   / TODAYS SEAT TIME #13,303
Mowing blackberry bushes with the 7' brush hog:
The view from the seat in the air conditioned cab:
   / TODAYS SEAT TIME #13,304
Supposed to get some seat time for hire this evening. Been 105º today... the cool of the evening could still be an uncomfortable 95. Not looking forward to it as I normally would.
   / TODAYS SEAT TIME #13,305
104 forecast here today.... today's seat time will be on a mini excavator I rented for the weekend. Here is a video from some of yesterday's work:
   / TODAYS SEAT TIME #13,306
6 hours for hire on the machine in the last 3 days. 2 evenings and and a 2 hrs this AM. Pretty hard digging in rocky clay roil that was akin to the hubs of hell.
Broke a tooth off a ripper. So I'll be ordering a couple of those today.
Glad to be done and I got some jingle in my pocket. :)
   / TODAYS SEAT TIME #13,308
I did some bushhoging and loaded out some junk from my backyard.
   / TODAYS SEAT TIME #13,309
Cloudy here today and temp in 80's only got a sprinkle
very dry here. Hauled some more brush and tree branches
and moved some more dirt washed a load of clothes. Had
to go to town to get some small metric 1/2 inch sockets replacing
the intake heater on my truck.It sure would have been nice if
we didn't have to go metric!!!!!!!!!
willy
   / TODAYS SEAT TIME #13,310
FIRST COOL EVENING IN SOME TIME. 75º
Just finished up a little weed abatement. Tumble weeds and such had repopulated 2 areas I usually scape bare for a fire break. The weighted land plane did a stupendous job of skimming the weeds off. Enjoyable tractor time with intermittent rain drops (hardly a shower) but nice.
The added weight has made this LP do it's job. Before it would skim over tough weeds - now it just cuts them off clean. Worked until dark - Pictures later
   / TODAYS SEAT TIME #13,311
The weeds must pass through and lay on the surface. Do you keep going over them to grind them up or just let them dry up and blow away ? I use mine on sod growing in the road edges or parking areas.
gg
   / TODAYS SEAT TIME #13,312
gg
Mostly they got ground up. There was a bucket of weeds to dispose of here and there. There is less to haul away and throw in the ravine if I do it more often but I let it get a little tall this time. Tumbleweed and Mustard make up the majority of the weeds.
   / TODAYS SEAT TIME #13,313
The place we moved into is on a hill with some bedrock not too far under ground. Spent the afternoons this week after work on a terracing project. Goal is to create three flat areas up the hill in the fenced in backyard with the objective of putting in a garden and eventually a greenhouse.
I did level 1 last fall. This week I was able to do level two and get a start on level 3. Tricky and slow part is getting the tractor in position and creating a flat spot to work off of. It goes fast after that. The slope does not look bad, but it sure felt iffy! Seatbelt on and moving very, very slow.... Plus some hand rake work to move dirt to the downhill side on occasion. All it takes is one hidden rock on the uphill side, or an obscured hole on the downhill side to ruin the day.
Tier 2 (Tier 1 is below it, with the bee hives) The uphill side is pretty much level down to the bedrock.
The start of tier 3
   / TODAYS SEAT TIME #13,314
The start of tier 3
That is coming out pretty good (y) Side hill work is hard on your nerves. Is it all bucket work or are you using a blade too ?
gg
   / TODAYS SEAT TIME #13,315
I ran out of gravel before I got to grade but the stand on skid steer is doing a really nice job putting gravel inside a building.
   / TODAYS SEAT TIME #13,316
It’s probably still low from grade, I was working without a transit but the shed floor is almost done.
   / TODAYS SEAT TIME #13,318
I sprigged my pond dam overflow. Perhaps a little risky this late in the season, but I went for it anyways. This is bermuda grass for anyone not familiar... you can rip up some from one spot in your yard and till it into another and it'll spread out with runners and both spots will look like we'll established yards after one growing season.
   / TODAYS SEAT TIME #13,319
(y) Good luck - had to look up "sprigged". A new term for me.
gg
   / TODAYS SEAT TIME #13,320
I did a quick stump removal job of 4 stumps. I didn’t want to go get my mini x off a job and the skid steer stump bucket made pretty fast work of getting these out. The skid steer was pretty clean before I did a lawn dressing job over the weekend for the clean police. I had a little extra time on the rock hound rental from doing the yard and used it to clean up around my burn pile.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
New Holland 650 Hay Baler (A53317)
New Holland 650...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Doosan 750CFM Towable Air Compressor (A59228)
2015 Doosan 750CFM...
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
2008 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2008 CATERPILLAR...
