/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler
#51
OP
aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 18,079
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Given how eroded that one was, I don't know that it would have helped. Has PB blaster on it now.Soak it down with either PBlaster or a mix of ATF and acetone and let it sit for a while before trying to remove it. Little heat helps too. I see you need a new door gasket too. TSC will have that most likely in stock. Comes in various lengths. Whomever had it really neglected it but I'll still come and get it if you decide not to restore it...
Actually picked up rope gasket the other day, was 50% off at Lowe's #score.
This has a 1/4" steel plate on the top door and masonry on the bottom with a sight glass (I assume something like Pyrex)The model I had, which I can't remember right now, did not have steel plates on the doors. They were each covered with a masonry piece. The bottom door had a pyrex sight glass in it that let you see how the fire was burning which it looks like you have too.
It had some kind of insulation behind the steel plate on thebuoper door and everything behind the insulation is rusted and corroded.
Aaron Z
