To Ebbtide, drain locations
/ To Ebbtide, drain locations #1
JohnS
Platinum Member
Southern Tier NY
Jinma 284
Received your PM, but responding here, so others may see.
This info was from my 284, but your 204 is probably the same.
Transmission has four drain plugs, two at the bottom and to the side of the swinging drawbar. Another is on the transfer case just below the transmission, and the last is just forward of tansfer case over the front drive shaft cover. Be prepared for allot of oil, most will come out of the two bottom plugs, near drawbar!
Front axle has a small drain plug near the bottom of each front wheel hubs. Small square hean on the plugs.
Hydraulic oil drain is on bottom of upper 3pt link mount.
/ To Ebbtide, drain locations #2
Thanks a bunch John!! /forums/images/graemlins/grin.gif I also had a response from Chip. You guys are da best.
/ To Ebbtide, drain locations #3
Mike, I was away for a couple of days, sorry I did not get back to you sooner, but looks like Chip and John help out.
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
New Electric Scooter (A65579)
New Electric...
HD Quick Attach Grapple (A66408)
HD Quick Attach...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
