TLB 110 rear remotes
/ TLB 110 rear remotes #1
ugo4it
South shore,Nova Scotia, Canada
TLB 110
I have a question on how to get the rear remotes to operate on the TLB 110. I have the three rear remotes along with the front. I have a cyl. with quick connect hoses for testing. My problem is I can not get the cyl. to move.
I turn on the hyd. with the switch I/O and the display shows the four arrows for the front remote, so pressing the button on the remote(joy stick) will change the display to the rear remotes and the four arrows for the rear light, this seem ok. Next is which quick connects to plug into, if I use the top (side by side) and press the top or bottom button on the remote(joy stick) my cyl. should go in or out???
Also if I connect to the middle and use the joy stick in a side to side movement it should go in and out? The bucket operates.
Also if I connect to the bottom and use the joy stick in a forward to back movement it should go in and out? The loader goes up/down.
What is the trick/step I am missing?
/ TLB 110 rear remotes #2
Sounds like your diverter valve is not functioning. Maybe seized up from lack of use? Might just need to be pulled apart cleaned. Or electrical problem, broken wire, blown fuse, bad corroded connector, bad solinoid, etc.
I agree with you, My plan is to check the signal to the valve, then check the spool and find a service manual.
Thanks for the input.
the diverter valve was not turning on. Found broken wires in the connector to the valve.
Thanks for you help.
1985 Rolls-Royce Sedan x14250 (A62613)
1985 Rolls-Royce...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
3098 (A63117)
3098 (A63117)
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
