Tires tires
/ tires #1
mit
any ever changed a tractor tire? i want to paint my rims with spray paint but i do not want to get paint on the tires.the rims has some rust and scrapes.would like to make it look good. how difficult to remove tires?
/ tires #2
If you haven't done it before and really, really want to paint the rims I suggest getting some jack stands and take all 4 tires to a tire shop. It's a tough job unless you have a bead breaker and some tire spoons, air compressor, experience, etc.
/ tires #3
I painted my 4 wheels for my trailer last weekend and I removed the wheels from the trailer and used 2 inch masking tape and trimmed the wheel edge with a razor knife and put another row around the edge of that and I had some minor over spray on tires that I washed off very easy.
I used a regular spray gun with very low pressure and I had real good control of paint
It was time consuming but the results are nice, I'll take some pictures this weekend and post them in my gallery here
Jim
/ tires #4
Jim
Same thing here. Masked the tires off and any overspray is easily removed with a little water and scotch brite pad or steel wool. Much easier than removing the tires.
/ tires #5
Duh, I did it the hard way ? I used Rust-O-leum paint and I used car gas and my tires look real purty now, real easy to do with the right stuff
LOL
Jim
/ tires #6
I'd just mask off the tires and paint them. Taking them off seems like too much work :cool:
/ tires #7
Well, I take the middle road. Use a tire spoon and hammer to move the bead down about 1/4 inch. Then cut cardboard to slide between the tire and rim, paint rim, remove cardboard, air tire.
done
/ tires
the masking idea sounds good enough for me.will give it as go .
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
250 GALLON FUEL TANK (A64280)
250 GALLON FUEL...
