Tires for a 2210
/ Tires for a 2210 #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I am looking for thoughts on the type of tire to get on a 2210 /forums/images/graemlins/confused.gif.
My property is very hilly. Some areas are fairly steep. I have owned two garden tractors with turf tires. I got stuck several times with the turf tires. I now own a 455 with bar tires on the rear. I have never gotten stuck with the bar tires, but all the trees that are on slopes have a rut around them were the inside wheel would slip a little & dig up the sod as I mowed around them. Just having 4WD on the 2210 should help stop that problem. When I first started looking at trading I was going to go with R1s. Then they offered R4s & I thought I would go with those. I drove a 2210 with R4s at the dealers & was not happy with the ride. It was very rough. I also read some threads here about the HDAP tires on 2210s.
I will be using the 2210 for mostly mowing in the summer with some loader, landscape rake & grader work. In the winter I will be using a front blade & snowblower on a sloped paved driveway. The 455 with bar tires has handled the winter work very well with out using chains & I do not want to use chains on the 2210 as they are to hard on the asphalt.
I will not be using the 2210 for any heavy loader or dirt work as I have a 4710 for the heavy stuff.
I stopped by the dealer after work today & the 2210 is there with the loader, mower & turf tires installed. They are waiting on me to decide what tires I want (R1s, R4s Turfs or HDAP). Then they will do the final check, wax and deliver it /forums/images/graemlins/grin.gif. I am hoping to decide by monday.
Chris
/ Tires for a 2210 #2
I have the bar tires. It seems to do fine.
I would have bought turf's if I had a bigger tractor like you do. There are some guys that still do loader work ect with the turfs without any problems.
/ Tires for a 2210 #3
Chris, I just saw you were from Liberty. If you want to try mine out I am outside of Greensburg. You can cut all the grass if you want. /forums/images/graemlins/grin.gif
/ Tires for a 2210 #4
I happen to have the x-series HDAP tires on my 2210. The dealer wanted to pretend he couldn't get a 2210 that way so I had to buy his demo. they were on the 2210 because a customer didn't want the HDAP's on his new X series SE so they swapped for the turf tires oon the 2210. I should think if one insisted theJD dealer can certainly get a set of HDAP's. After all, the x series tractors might need replacements. Anywho, I LOVE the HDAP tires, I get great traction in the dirt and i can't wait to try them in snow. they hold onto turf on steep slopes but be careful of spinouts as they can tear the turf a bit, engage that fwd on those slopes, esp if you're trying to back up a slope the 2210 seems light in the rear and loses traction.
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
(APPROX. 20) WOOD VEGETABLE BINS (A64276)
(APPROX. 20) WOOD...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
