Tires Tires For 1300D
/ Tires For 1300D #1
Anonymous Poster
Epic Contributor
Does anyone know if the 1300D and the 1401 have the same size tires front and rear? The 1300D has 8-16 rear and 5-12 front or for turf tires 6-12
Thanks
Hondo /forums/images/graemlins/cool.gif
/ Tires For 1300D #2
My 1401D has 8-16 tires on the rear and 5-12 on the front. I just had some LT235/85R16 tires mounted on the back and they work perfectly as turf tires. They are almost exactly the same outside diameter as the 8-16 rice tires.
/ Tires For 1300D #3
Yup, my 1300d and 1401d have the same tires as you and Hosejockey. /forums/images/graemlins/laugh.gif
Jim
/ Tires For 1300D #4
The 1401 has 8x16 on the rears
and 5x12 on the front, you are correct.
Its the bolt pattern that matters.
Ern. <><
/ Tires For 1300D #5
265/75R16 are also the same diameter as the 8-16 tires. I have a YM1301D with 8-16 rear and 5-12 fronts. I replaced the 8-16 rears with used Michelin 265/75R16's that I bought from a local ag tire dealer for $5 each. They work great as turf tires are are a bit wider than the 235/86R16's.
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
207273 (A52708)
207273 (A52708)
FORKLIFT (A56857)
FORKLIFT (A56857)
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2008 New Holland T2420 (A62177)
2008 New Holland...
