Tire won’t take air.
   / Tire won’t take air. #31
I will use head gasket goop on the rim at the bead area, sometimes also on the tire bead, too. Then when you push the carcass towards the rim, it sticks, and the airflow will fill it.
I've also use the starting fluid technique with great success ! just a spurt. Done. But it takes some 'sperience to know how much is enough. For this to work, the tire bead has to be tight on the rim. Many of the imported tires now are too loose on the rim to stay put.
   / Tire won’t take air. #32
squirt of ether and a lighter...but i didn't say that.....
   / Tire won’t take air. #33
On larger tires I have successfully used a ratchet strap around the circumference and snugged it up to compress the tire, maybe something similar with tie wire to cinch the tire up.
That works on most soft tires such as automobile and lawn equipment. ST trailer tires are heavy and stiff. The problem with the strap is that it doesn't slip so only the section under the ratchet gets most of the compression. I had to use 2 ratchet straps, tried to use 3 but the strap to hook was too long. Got 3 out of 4 tires inflated then finally took the 4th to a tire shop and pleaded for mercy. Tire tech got a good laugh. Put the wheel on his machine that has a ring of high volume air blowing up under the tire which obediently popped into place. I gave him $5. A bargain.
   / Tire won’t take air. #34
remove the valve core and plug just a male fitting into your air hose and use it on the valve stem.
   / Tire won’t take air. #35
Not all air hose chucks will inflate a tire valve without core. I have one now but did not then.
   / Tire won’t take air. #38
Put Slime in the tire, & try the ratchet strap. I keep Slime in all my small tires--they stay inflated much longer, and I've never had any problem.
Wells Cargo 10ft S/A Enclosed Cargo Trailer (A48082)
Wells Cargo 10ft...
2007 GMC C8500 Ox Bodies 12Yd T/A Dump Truck (A48081)
2007 GMC C8500 Ox...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2012 Chevrolet Tahoe LS SUV (A48082)
2012 Chevrolet...
Bradco 78in Skid Steer Grapple Rake (A50490)
Bradco 78in Skid...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
