DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,577
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Not worth it for one tire, but do a search for a bead seater tank. I've wrestled/strapped tires from the size you speak of, to 12 ply trailer tires that were stubborn about popping out on the rim. I lucked out 2 years ago, and found a nice used Cheetah brand locally on the FB Marketplace for $40. It's paid for itself many times over, and saved a lot of aggravation. They dump a high volume of air through that gap between tire and rim. Pops it out in a nano second. Maybe check with one of your buddies, and see if they have one.
Along with that, I bought a quart can of brush on bead sealing compound, to seal between the bead and rim, sealing imperfections where you get a slow leak. Any auto parts store should have it. I had a new front tire on my Cub Cadet that would lose air over a period of a couple weeks. Broke it down enough to seal the bead on both sides, used the bead seater tank to pop it out on the rim. Haven't added air since.
