Tire Valve
/ Tire Valve #1
paulharvey
Hawthorne, FL
Kubota L285
I have water filled 12.4-24 AGs on my L285 Kubota. On of them is slowly leaking air and water around the valve stem. I don't know the name for the part, but it's like a nut holding the stem tight against rim? It's plastic nut with a crack. Is that the reason it's leaking, or is it an unrelated piece? I know it's a dumb question, but ...
Attached is a picture of what I mean.
If it's caused by that cracked part, what's it called, so can get a new one.
/ Tire Valve #2
The valve stem should be replaced. Don't think you can just get the nut.
/ Tire Valve #4
Where is it leaking at the nut or out of the valve core
/ Tire Valve
It's leaking around the base of the valve stem, not the core. It's pretty slow, maybe go from 35 psi to 20 in a week.
/ Tire Valve #6
The plastic nut comes with the tube to hold the stem in when installing the tube. If it is leaking around the stem you have a hole in the tube.
/ Tire Valve #7
Hole in the tube is the correct answer. Remove wheel. Deflate tire. Remove from rim. Patch tube. Reassemble. Of course if you want water back in it I'd go to a tire shop.
/ Tire Valve
Ok, that helps. Tube it's self has leak, and air/water is moving inside the tire till it gets to path of least resistance. Makes sense, thanks.
/ Tire Valve #9
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
CAT D8 (A58214)
CAT D8 (A58214)
John Deere Gator (A53317)
John Deere Gator...
