Tire Valve
/ Tire Valve #1
paulharvey
Hawthorne, FL
Kubota L285
I have water filled 12.4-24 AGs on my L285 Kubota. On of them is slowly leaking air and water around the valve stem. I don't know the name for the part, but it's like a nut holding the stem tight against rim? It's plastic nut with a crack. Is that the reason it's leaking, or is it an unrelated piece? I know it's a dumb question, but ...
Attached is a picture of what I mean.
If it's caused by that cracked part, what's it called, so can get a new one.
/ Tire Valve #2
The valve stem should be replaced. Don't think you can just get the nut.
/ Tire Valve #4
Where is it leaking at the nut or out of the valve core
/ Tire Valve
It's leaking around the base of the valve stem, not the core. It's pretty slow, maybe go from 35 psi to 20 in a week.
/ Tire Valve #6
The plastic nut comes with the tube to hold the stem in when installing the tube. If it is leaking around the stem you have a hole in the tube.
/ Tire Valve #7
Hole in the tube is the correct answer. Remove wheel. Deflate tire. Remove from rim. Patch tube. Reassemble. Of course if you want water back in it I'd go to a tire shop.
/ Tire Valve
Ok, that helps. Tube it's self has leak, and air/water is moving inside the tire till it gets to path of least resistance. Makes sense, thanks.
/ Tire Valve #9
